The AUX switch kit you buy is not the same as if the vehicle come with it
supermike
mike
Irvine CA
18 JLUR 6 speed 2021 JLUR 392
Mine did not come with the HD pkg, so I added the mopar aux kit myself. Noticed today when adding another circuit, the mopar kit does not have "battery power" nor "ignition accessory power" like the OEM one does, and the coloring is different. I attached some pictures to clarify.
This is what you get if the kit was install in factory....
Jeep Wrangler JL The AUX switch kit you buy is not the same as if the vehicle come with it Jeep Acc
This is what you get when buying mopar kit and add it later...
Jeep Wrangler JL The AUX switch kit you buy is not the same as if the vehicle come with it WechatIMG112
Jeep Wrangler JL The AUX switch kit you buy is not the same as if the vehicle come with it Mopar_82215190_Black_Auxiliary_Switch_Bank_Kit_Front_0
RubenZ
Ruben
Deep South Texas
myjlproject.com
2021 Ford F-250, 18’ Toyota 4Runner
Ya this was a bummer when I added mine when I had the JL. Its not the exact same setup as OEM even though its OEM lol.
paffemt
Chester County, PA
2019 JLU Sahara
That’s probably due to the other 2 circuits being on the inside only and probably feed from a location inside the jeep and just get bundled with the Inside switched wires when factory installed
Jdsmoke
Derek
Bucks County, PA
2019 Wrangler Sport 2 door
Healthcare
Bummer. Just added this. What would the 2 cables be used for?
paffemt
Chester County, PA
2019 JLU Sahara
I take it you are referring to the two circuits not included with the aux switch kit. One is for ignition switched power and the other is constant power.
