That's where my 24mm wrench went!
AVGeek99
Delano, MN
2021 JLUR, 2024 Rubicon 4xe (wife's)
I've been battling a steering shimmy and occasional DW since I got a lift installed in November. A few weeks ago I corrected my castor, and when done with that I loosened and retorqued all suspension bolts.
A couple weeks ago I was going through my tools and my 24mm wrench was gone. I knew I had used it when torqueing the front LCAs and I figured I must have left it on and forgot about it. Then I had driven it for a couple weeks so if that's what happened it was gone.
Then today I was under my Jeep installing Steer Smarts Yeti TR and DL. While under the Jeep I noticed something shiny in the corner of my eye. I looked and there was my 24mm wrench. Still connected to the LCA nut. :LOL:
Jeep Wrangler JL That's where my 24mm wrench went! 20240309_165217
Duece McCracken
Croydon, PA
2023 JTR 6spd, 2019 Mustang Bullitt
Lucky you!
Jeep Wick
Wick
America
2022 High Tide
Mechanic
I left a small allen wrench on my rear bumper when I was doing the tow harness...drove around a week and it rained last night, it was still there!
JLfromCA
JL
2019 Mojito! 2 Door Rubicon/2024 Sarge Green 392
what year is your Jeep, the underside looks clean but the exhaust pipe ?
AVGeek99
AVGeek99
Delano, MN
2021, salty MN Winters. It's not really as bad as it looks though.
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
2023 JLWS 6MT
Happens
Mine is a '23, underside is still super clean, but the exhaust looks awful!
Fairly certain it's mostly just baked on red dirt. lmao
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Glad you found it! Still trying to figure out how you check torque with a combination wrench? I have a click in my shoulder that goes off at about 65 ft-lbs but need a torque wrench for everything else ?
When the torque spec is 190 ftlbs, it really needs to be "extremely tight". You won't break it by hand. If you weigh roughly 200 lbs its easy, use a 1 foot wrench and go until it holds your body weight.
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
Local CDJR dealer topped off my coolant ("free Jeep Wave").
60 miles later, < 1 mile from pavement, cap blew off coolant tank. Steam. No sign of cap.
Event followed by tow, purchase of coolant and new cap. Dealer shrug.
12K miles later, while looking for firewall feedthru options, what do I see on the frame rail? ?
Jeep Wrangler JL That's where my 24mm wrench went! CoolantCa
roaniecowpony
Retired Engineer
roaniecowpony
Retired Engineer
Looks like you clean the underside with a pressure washer?
BobW
Bob
Ventura County
