TFLtruck tests 3.0D 2020 Ram 1500 mileage.
Sgt Beavis
Rick and Miyako
Wrangler JL Unlimited Sport S
The Man, The Myth, The Legend. In my own mind.
Very interesting.. Though TFL admits they need a redo.
ldstruckn
joe
Timnath Colorado
79 CJ7, 82 CJ7, 88 YJ, 2000 TJ, 2008 JKUR, 2012 JK sport
VA Doc
if true then 40inch tires on a JLUR should be in high 20's easily, may not even need to regear thanks to all the low end twin scroll grunt.
JLURD
Alaska
2018 Compass Latitude 6MT, 2020 JLUR 3.0
Not a chance. The aerodynamic efficiency of a bone stock Ram 1500 vs a lifted wrangler are light-years apart. Add to that the rolling mass of 40s, the gearing of a wrangler diff and the near impossibility of that Ram highway number being accurate, you’ve got a recipe for low 20s in a lifted JLU on 37-40” tires. Still great compared to mid to low teens, but I’ll bet a serious stack no JLU 3.0 rolling 40s hits the high 20mpg’s without Jesus driving it downhill in a vacuum.
Sgt Beavis
Sgt Beavis
Rick and Miyako
Agree with everything you've said, but one more point to consider. The Wrangler JLU, at it's heaviest (4430lbs), is more than 300lbs lighter than a 2020 Ram 1500 at it's lightest (4798lbs). TFL wasn't driving the lightest Ram 1500 at all. It was probably closer to max weight of 5372lbs.
IMO, the Wrangler is going to have the same or better MPG than the RAM 1500.
ldstruckn
joe
Timnath Colorado
VA Doc
like i said "if true". then a 25 percent efficiency reduction for aero and rotational mass is realistic considering the weight difference. simple physics. to bad we do not know gear ratios and if the ram numbers were true.
At the 2019 Ram 1500 announcement it was stated that the new drag coefficient of .357 was specific to the Quad Cab, 2wd version with Active Air Dam.
2018 jeep wrangler unlimited rubicon is .454
just for comparison a hummer h2 is .57 so a lifted jlur will be between .45 and .57
JLURD
Alaska
Diesel engine and emissions nonsense are expected to add over 100 lbs to the current heaviest spec iirc. Add in the weight of steel bumpers, 37-40” tires, winch, lights, hi-lift, compressor, recovery gear, roof rack, snorkel, skid plates etc and you’ll wind up as close as makes no difference to a RWD 1500.
