viper88
Nick
IL
I've heard folks say the steering in the Bronco is soft and disconnected. Not good for offroad, but great for highway.
The steering for the Bronco and Wrangler are intentinally designed the way they are. I think both are going after a different goal. After driving both I don't think many would argue the Bronco has better on-road steering feel and the Wrangler is better off-road. The Bronco is like driving any other pick up or suv. Very good on-road. The Bronco is soft and disconnected compared to a BMW suv but has MUCH better steering feel than a Wrangler on highways.
Mikester86
2022 JLR
Don't forget about steering feel. The Bronco has that in spades over a Wrangler. Steering feel might possibly be the deciding factor for a lot of potential customers cross shopping both?
Until I drive a Bronco, I cannot say for sure how big the difference is. But yes, IFS typically is a better, tighter feeling driving experience.
Zandcwhite
Zach
Patterson, ca
2019 jlur
The steering for the Bronco and Wrangler are intentinally designed the way they are. I think both are going after a different goal. After driving both I don't think many would argue the Bronco has better on-road steering feel and the Wrangler is better off-road. The Bronco is like driving any other pick up or suv. Very good on-road. The Bronco is not BMW connected but is MUCH better steering feel than a Wrangler.
IFS and rack and pinion steering will always provide a better, more car like drive on road. A solid axle gives up street comfort and handling for articulation, simplicity, and ease of modification. It's simply the nature of the different suspensions. If you want a street Cruiser that can still wheel, the Bronco may be the better choice. If you're more concerned with the off road performance, although the jl is still great on road compared to a tj or even a jk, the Wrangler is the better choice.
viper88
Nick
IL
There is signifigant difference for sure. IFS makes a difference but I think a lot of the steering difference is the Bronco's rack-in-pinion verses the Wranglers steering box. Ford learned from the Raptor and other products they make.
MrMischief
JL Rubicon
I don’t think lockers were even necessary in the Jeep for this trail. I could be flawed in my thinking, but BLD may have been enough.
Yep I used to to run this in my first TJ which was open front and rear without issue. I do use my lockers up there now, because I have them and I feel that I'm less likely to spin a tire and tear up the trail anymore than necessary. I haven't been up there this year, but unless something has dramatically changed any Jeep can get through this trail. The worst part truly is that rock right at the beginning but with spotting and careful driving you can get through it. Andre did not do a good job of going over it (too much speed IMO).
It is hard to tell how steep it is but from the video I think the Jeep might have made it in 2wd if you could disconnect the swaybar in 2wd...The Bronco had to go fully locked on 35s to get up the flexed out section although I imagine it could have made it with just the rear locked.
That section where the bronco is flexed out is fairly steep, it's right after a switch back so not much room for a run up. I'm sure someone could get through there in 2wd, but it wouldn't be a graceful walk up it. My 2 doors lift tires there. I am curious about the differences in wheelbase on the JLU and the Bronco 4 door, I would've liked to have seen where the rear tires were. Honestly I'm kind of disappointed that they ran Red Cone on a Sunday. It's a busy trail, you can see people constantly around them, and I feel that they may have rushed some of the shots to get out of the way of other trail users. Nice of them to not hold people up, but had they ran it on a week day it would have been more quiet up there for them to take time getting more shots. I believe they ran Wheeler on Monday, that should be a great video as it is a more difficult trail than Red Cone.
Your comment made me think of the last climb to the top on the video.
I can really see the guy in the Jeep rocking back and forth and the crew in the Bronco with noticeably less head toss.
It's totally an issue (feature?) of solid axles. Some trails, maybe many trails, I would like to have at least IFS to help smooth that out some, but I really do like solid axles for their strength, articulation, and relatively low cost to repair/replace/lift. I don't know that I'm going to run out to replace my JL with a Bronco anytime soon, but I am certainly paying attention to it. Super excited that they're starting to show up in CO now so I can watch them on trails I know.
I've found that the washboard smooths out if you drive at higher speeds than the Subarus that caused it.
All vehicles cause washboard. My theory on it is anything travel faster than say 4 mph when a bump is hit the tire displaces loose material which quickly starts to pile up near by. This then just continues to replicate itself over and over. The rhythm of the washboard will be related to the average speed of vehicles on the road. Traveling fast enough you can "skip" along the top of the washboard, smoothing out the ride for yourself. But if the rhythm of that washboard changes, or if the peaks get higher/lower, you're crashing your tire and suspension into the washboard rather than skipping along the top until you find the correct speed again. For myself, it depends on the road and how safe I feel it is to be going at the speed necessary to skip along the top. I either go very slowly through washboard, or fast enough to skip along. I always slow down for oncoming traffic though, both for their visibility and to hopefully not pepper them with gravel.
Would a JLUR on 33s make that first ledge without body damage? I'm a few hours away from that, but our plans changed here in Colorado springs and might make a day trip out if it.
Yes a stock JLU can make it up there without damage. Of course you stand a chance of damaging something, it is a tight spot, but just take it slowly and carefully and it's not an issue. If you go on the weekend it's a busy trail, so if you don't have a spotter you'll likely have someone else there who would be willing to help. The top of red cone is a great view (it'll be windy, and seems to always rain on me when I'm there). Going down the backside is what Red Cone is known for. Used to be challenging but in modern vehicles it's a non-issue. Steep, but keep it in 4 low use your hill descent if you like, it's not as dramatic as some books would have you believe. It drops you out onto the top of Webster pass. Great view from there as well. Take a left down some narrow switch backs and it's an easy trail back to where you started Red Cone (the snow that blocks the way should be gone by now). Or go straight/right, stay pointed down hill and it's an easy trail down to Montezuma and eventually Keystone, there is a nice creek crossing as you get to the end. If you're feeling frisky right after the first creek crossing you head straight/left/uphill and almost immediately you get to where TFL has done some other videos. Keep going that way and you're on Radical Hill which is a more difficult trail with very narrow switch backs that end in a steep climb putting you back up on the tundra. There is almost always mountain goats there. Several ways off that mountain, all of which are pretty easy (other than back down Radical Hill) and drop you back into Montezuma/Keystone as well. I forget the trail names up there, Saints John is one of them its the longer way out, but it's scenic. From Keystone I recommend find your way to Dillon, stop in at the Dam Brewery for good food and drinks before jumping on I-70 and TFL's Ike Gauntlet (which I believe currently is under construction).
entropy
Foothills of the San Gabriels
Jeep Wrangler Sport S JL 2-D
Well what we all thought. Bronco lifting a tire due to IFS.
Bronco works. It'll satisfy its customers, it is a good platform. People buy 4runners over Wranglers, they'll buy Broncos too.
I am keeping my Jeep, and doubt I'll be getting a Bronco in the future. I don't like to have tires hanging on the air. Sure the lockers still push the vehicle, but it isn't safe. Then you have to maneuver that giant thing on the trail. nah. Then there's the strength and durability of a solid front axle. The Wrangler is just better offroad.
ThirtyOne
Chapel Hill, NC
www.jeepdoodles.com
Not sure. Lockers would help. But I’ve never seen anyone without a lift and 37s do it. It’s harder for 4-doors too. I think departure angle would be a problem without a lift.
@chevymitchell would be the one to ask.
ThirtyOne
Chapel Hill, NC
www.jeepdoodles.com
Good to know. I have a similar setup - maybe I’ll give her a try next month 😁
Let me know when you want to go out there. I know a couple of guys that can spot anyone though it.
Sean L
Sean
North Carolina
Great video, as usual.
SPOILER ALERT!
The Defender's 20" wheels see two flat tires within about 50 yards. Gets left for dead. Womp womp.
The Bronco is noticeably bigger than the Wrangler, can't choose its lines as carefully due to its size, and doesn't articulate as well.
The 4xe puts in a strong showing by running battery only for 3.1 miles of very gnarly trail. With 35s on the Wrangler, it clearly would have been the walk-away winner. The Bronco seems like a great competitor, but...
MEGA SPOILER ALERT! Tommy drops an F-bomb.
So I sat down and watched the video last night. Depressed because the tires I used to have on the jeep were the same as the ones on the Land Rover. I also had to replace two of them for flats, just not off road.
Sean L
Sean
North Carolina
Sign me up too! I've been wanting to try out Daniel but only if someone that's done it before is there too.
xjgary
Gary
Carpinteria, Ca. USA
1993 Cherokee XJ
Articulation. Same obstacle, with the swaybar disconnected on both vehicles. :LOL:
These pictures say everything I need to know. Nothing beats tires on the ground getting traction.. Ford claims greater articulation than Jeep, but this is the real world, not a ramp.
Outrun
PNW
2021 392XR
Until it’s time to go through some whoops or catch some air… then Bronco dominates. Is wrangler going to be better in the rocks? Absolutely. But Bronco is WAY better in the desert running stuff. It’s all trade offs.
The IFS system it has is 1/3 of what actual off road vehicles use. It's like a hybrid solid axle combined with IFS. In it's case, the worst of both worlds in the off road realm. You cannot setup enough travel with such short arms to take any of those whoops at respectable speeds. Bumpy trails, sure, no problem.
What you can do, is setup SFA to haul ass over whoops. The Bronco will be very limited and especially in the aftermarket as for performance due to it's inherent design where the Jeep can be setup to be KOH or Jeep Speed worthy without too much fuss. If you ever been to BITD you would know what I mean. Unfortunately, lots of keyboard commandos just sitting here speculating because all they have been fed was Ford's marketing.
The Bronco is not the first factory IFS car to enter the playing field.
