redracer
- Robert
- Aug 22, 2017
- Manteca, CA
- 2018 JLU Rubicon
I wired it by using the extra input/output cable... but, you don't need it per se, you can reuse one of the extra rca connectors(for example, AUX in) by removing / replacing the cables pin in the connectors. Specifically, it uses CVBS_IN1 on pin A18 and the nearest GND pin. Their harness shares one GND with a few neighboring signal cables.
I also wired in the long extension cable to the power cables in the adapter harness. I used red as + and yellow as - on both sides.
Then I went into the factory settings and enabled Front Camera, then the front camera app appeared. There is a button on the app to mirror the input so that the orientation is correct.
Have a look at the wiring diagrams below.
