alleycat
- Tom
- May 28, 2020
- Corpus Christi, Texas
- 2022 JLU Willys 2.0t
- Occupation
- Retired
The owners manual states:
4H To 4L Or 4L To 4H
With the vehicle rolling at 2 to 3 mph (3 to
5 km/h), shift an automatic transmission into
NEUTRAL (N), or press the clutch pedal on a
manual transmission. While the vehicle is
coasting at 2 to 3 mph (3 to 5 km/h), shift the
transfer case lever firmly to the desired
position. Do not pause with the transfer case in
N (Neutral). Once the shift is completed, place
the automatic transmission into DRIVE or
release the clutch pedal on a manual
transmission.
NOTE:
Shifting into or out of 4L is possible with the vehicle
completely stopped; however, difficulty may occur
due to the mating teeth not being properly aligned.
Several attempts may be required for clutch teeth
alignment and shift completion to occur. The
preferred method is with the vehicle rolling at 2 to
3 mph (3 to 5 km/h). Avoid attempting to engage or
disengage 4L with the vehicle moving faster than 2
to 3 mph (3 to 5 km/h).
transmission.
NOTE:
