word302
Yes. Love it. There's a couple good youtube videos floating around if you're more visual.. Will try this tomorrow!
I just brought mine to a local shop.Would you go to a dealer for an alignment or just an aftermarket shop?
No heartburn. The "ugh" was because I acknowledged your sentiment that it can be done ("What you described is do-able"), yet you replied with "I'd argue that it can be done right in your garage but to each his own." I thought that deserved an "ugh." I agreed with you, and simply offered my opinion on aligning larger tires.I'm not sure why that's giving you heartburn man. The small tolerances that you're speaking of just really aren't that hard to measure if you know what you're doing. Like I said, to each their own.
The size of the tire has 0 bearing on an alignment. You also have an interesting way of "agreeing" with someone.No heartburn. The "ugh" was because I acknowledged your sentiment that it can be done ("What you described is do-able"), yet you replied with "I'd argue that it can be done right in your garage but to each his own." I thought that deserved an "ugh." I agreed with you, and simply offered my opinion on aligning larger tires.
It totally does matter, if the alignment isn't perfect. A 40 that's slightly out of alignment will rattle your bones, while a 33 that's slightly out of alignment may be drivable.The size of the tire has 0 bearing on an alignment. You also have an interesting way of "agreeing" with someone.
That doesn't make sense, you're re-using the stock bolts that hold on the track bar to the brackets.The shop told me he had to cut the bolt for the track bar as it was to long and that track bar is usually put on vehicles with a lift. The jeep rides ok but going over some expansion joints on the highway created some wobbling and the jeep rides much harsher. Any ideas??
