Teraflex st2 front sway bar
Shellbird01
Bob
Ontario Canada
2018 Wrangler JL Shara Unlimited
I installed this kit on my Sahara in April (love it) it seems my sway bar sits much higher than other Jeeps but I used the links that came with the kit (I recall the box said JK for the links only). are they too high? Am I going to have issues?
chevymitchell
Shawn
K-ville, NC
2019 JLUR (Pain Train), 2022 2500 AT4
Avi Engineer
Double check that you have the shorter links up front. The front should have 10.75" and the rear should have 11.50".
BlackGenesis
Andrey
Muskegon Michigan.
18 Sahara unlimited
Sway bar Should be parallel with the ground - for best performance.
You will not get much flex the way it sits, unless you prefer stiff.
Shellbird01
Shellbird01
Bob
Ontario Canada
The front are longer than the back, time to switch
Petey
Pete
Miami
2020 jl sport manual
I agree, those things look like they don't have to much travel left before they start getting in the position where they just become a straight rod
Shellbird01
Shellbird01
Bob
Ontario Canada
chevymitchell
Shawn
K-ville, NC
Avi Engineer
Iā€˜ll post another pic when itā€™s done
Sounds good.
The bar will never be parallel to the ground. Just make sure you have the shorter links up front and everything will work as designed.
Shellbird01
Shellbird01
Bob
Ontario Canada
Itā€™s definitely lower. The back looks close to the tire balancing weights, Iā€™ll keep an eye on those. When I installed the lift it was stiffer than I expected but folks on line said it would be stiff. Opinions? Should I consider adjustable. Does it improve the ride.
Thanks for the input
Jeep Wrangler JL Teraflex st2 front sway bar F4503A40-E4E8-4551-99B1-1407FAC1BD84
Jeep Wrangler JL Teraflex st2 front sway bar 5AD6DC7A-8588-4A32-AB90-04ACE13069CC
SleepEatJeepRepeat
Newport Beach, Ca
2021 JLUR, 2020 Audi Q7
Looking at Jeep stuff all day
Anyone try running 37" K02 with the st2 using the bumpstop shims and have photo's feedback, reports of rubbing?
