might wanna go a touch higher to clear those 37s.I've been looking at this lift, but I want to run 37's. Not sure if 1.5" is enough to avoid rubbing on modest off-roading.
I have sold this kit and it will certainly help you clear the 35" tires and ensure zero rub.
Anyone run this for the JLU? Looking for sub 2" lift to run max 35s.
Where can I purchase this liftAnyone run this for the JLU? Looking for sub 2" lift to run max 35s.
Following up again. Onroad qualities of this lift?I have sold this kit and it will certainly help you clear the 35" tires and ensure zero rub.
That shouldn't matter much if you a running load c tires.I’ll tell you Friday as this set is being installed on my JL. Although, I am running 33”.
It's helpful to mention the load range when talking about on-road ride quality.I’m running load range e. Toyo 287/70/R17 with 37psi.
I did. Fine on road, crap ride off road. Added the falcon 2.1’s.Has anyone run this just using the rubicon shocks? If so did you use extensions? And how is the ride?
Heard the falcons are stiff, how do you like the ride?I did. Fine on road, crap ride off road. Added the falcon 2.1’s.
