gevo1
- George
- Dec 27, 2020
- Los Angeles, CA
- 2019 Jeep JLUR
Teraflex JT Rubicon 2.5" suspension lift kit with 3.3 fast adjust shocks. Selling for a friend.
Includes:
- Front and Rear Falcon 3.3 fast adjust shocks.
- Teraflex front springs
- Rear Teraflex spring 1.5" spacers. Original kit comes with 1/2" spacers only which don't provide adequate pre-load and will allow springs to fall out of place at full droop. The longer spacers separately purchased, provides appropriate spring pre-load at full droop to prevent this, while also increasing the rear height to allow a mild forward rake (not as much as factory) to allow for loading of the bed with weight. Teraflex does not sell appropriate rear springs for the JT.
- Front and Rear Teraflex softer bump stops.
- Front Teraflex bump stop extensions
What's not included to complete the full kit:
- Front/rear sway bar endlinks (one of the Teraflex fronts broke and we replaced them all, not sure where the rears are, if found, you can have those as well).
- Rear 1" bump stop extensions.
- Brake line mounts (we never needed to use them, if found, you can have them. These are good if you are running extended brake lines on a taller lift).
Asking $1,900. Located in So-Cal, Granada Hills area. Don't want to ship.
Also have other things for sale. Going to list them with details:
- EVO Plush Ride 2.5" springs Front & Rear for JLUR. $200
- Custom made aluminum bump stop extensions. $100
- JL Rubicon Factory Red stitched steering wheel, non-heated. $150
- Synergy JLUR Tie Rod (comes with Fox Tie Rod Clamp). $300
- Synergy Drag Link. $200
- JLUR Factory Rubicon Sliders. $70
- JL Rubicon Steel Bumper LED Fogs. $80
- JLUR Factory Suspension. $200
- JLUR Factory, all 8 control arms. $150
- JT Rubicon Factory Drag Link. $100
- JT/JL Rubicon Factory Tie Rod $150
- JT Rubicon Factory Rear Track Bar. $50
- JT Rubicon Factory steering stabilizer. $20
- Teraflex Tie Rod clamps both 1.5" diameter with different thread sizes (haven't bothered to check since I never used them). $40/both
- JT Rubicon launch edition wheels/tires and spare. Factory 33" Falken Wildpeak A/T tires. 1 day old. $1,500
Thanks for looking.
- George
Includes:
Thanks for looking.
- George
