- Brett
- Sep 14, 2018
- Navasota, TX
- 2019 JLUR-8 speed 2020 F-350
- Banned
- #16
new driveshafts are strongly encouraged with an MC lift because of the amount of travel (compression and droop) the rocksports and 6 paks have. There’s a cross member that restricts droop and tears the factory driveshaft. The new one is smaller diameter but stronger and comes with 1310 joints. I completely understand the added expense ($599) and will always will encourage it, you can get by with the factory one especially on a rig that’s not being wheeled very hard or often though.MC suggest a different shaft replacement for the 2.5 inch lift. Is that really necessary? That takes the expense to another level even with the less expensive shocks. While I understand quality for performance I most likely won't be rock crawling at all. I do however want to have stuff that isn't going to mess up my ride. I don't mind buying arms in peices from a different company than the company I get the lift from to help keep expense down and slow me to put together over time.
Often times what leaves my shop is headed straight to Moab or local wheeling locations so I tend to err on the side of caution and suggest knocking it out at the same time. The shocks are the same between the 2.5 and 3.5” lift.
brett
