TeraFlex 1.5 spacer lift question.
NPE102414
Peter
Pelham New Hampshire
2020 JLUR
I just finished installing the front spacers on my 2020 Rubicon and the springs just don’t look right the way they’re seated in the upper spring perch. Can anyone that has this lift and installed it please chime in. The bottom is seated perfectly and the tops are in the notches correctly, It just doesn’t look right even though it’s installed correctly.the spring are straight and everything is lined up, just doesn’t look right the way the spring is sitting in the upper perch.
the.jl.adventure
JJ
Grand Rapids
2019 Jeep Wrangler Rubicon Unlimited
Executive Chef
I agree with you, those don't look right for some reason... almost seems like the spring slipped behind/inside the factory spring rest.
I just ran out to check mine since I am running the same 1.5" leveling kit from Teraflex. Mine do not look like that, they seem to be very level with the factory spring rest and make contact all the way around. I would pop them off and try to adjust them a bit. I really am not sure how they would shift that much, especially since it does look like you have the bottom of the spring seated correctly.
Side Note: I do have a decently heavy steel bumper and winch setup on the front... maybe that is causing mine to sit better. Just a thought.
I included a picture of mine for comparison.
Jeep Wrangler JL TeraFlex 1.5 spacer lift question. 20201010_153356 (1)
Mjanski
MJ
Maryland
2018 JL Sahara
Mine are sitting similar. I questioned this before this post and had everything rechecked by the installer and they saw no issues. Might be a question to ask Teraflex next.
Jeep Wrangler JL TeraFlex 1.5 spacer lift question. 2AC5B9C4-87EA-495F-A561-D5B5DDAAD5E4
Redneck_Jedi
Currently Roaming
2019 Jeep Wrangler Sport S 2 Dr.
Redneck_Jedi
Currently Roaming
