Biconia
- Kenny
- May 15, 2018
- Los Angeles CA
- 2018 Rubicon JL
- Vehicle Showcase
- 1
Here i am selling my USED Teraflex 1.5" Perfomance Spacer lift kit + 2" Bump stop kit
asking $ 220 Shipped w/ USPS Priority
Works with stock length shock absorbers
This kit also corrects the factory rake to give your JLU Wrangler Unlimited some attitude thanks to a more aggressive stance. Not only does the 1.5” Performance Spacer Lift Kit clear larger tires, but the additional height helps compensate for heavier aftermarket gear such as bumpers, a larger spare tire, or weekend swag.
The TeraFlex JL/JLU: 2” Bump Stop Strike Pad Extension Kit extends the reach of the factory bump stops on lifted JL/JLU Wrangler models to soak up energy during hard compression and suspension movement. Combine with our JL/JLU: 0.5” Bump Stop Strike Pad Shim Kit(s) (# 1959300) to fine tune your strike pad height.
*Check before and after Spacer pictures
OEM 33" tires in the picture
35" Tires in this picture
