Temperature Sync permanently?
wchevron
RI
2021 JT, 2020 JLU
I found the Sync button on the climate panel. Is there any way to lock it so each time you are in the car, the temps are synced?
jludave
The Isle of Long
IT Manager
If you leave the setting set to sync, it will stay that way.
JimmyZ
Jimmy
2021 2-Door JL Snazzberry Rubicon
I dont have my jeep yet, but if its like most other vehicles, it will remain synced until the passenger adjusts their side of the thermostat. At that point it will no longer be synced and it would take going back through and resyncing for it to sync again. Hope that made sense
Renegade
Zac
Signal Mountain, TN
‘20 JT
This is accurate.
wchevron
wchevron
RI
2021 JT, 2020 JLU
Thanks. I have to figure out what my daughter is doing when she drives. Everytime I get back in the Jeep the sync is off and the temps are all over the place. Kids....
pixeldecals
Rock Sponsor (Level 1)
Chicago Area, IL
www.pixeldecals.com
2018 Sting Gray JLU Rubicon, 2013 JKU Rubicon
The Tazer has a setting for enabling Dual Zone Climate when upgrading to the larger radio from a basic one. I wonder if this could also be used to disable dual zone when you don't want the feature?
Renegade
Zac
Signal Mountain, TN
‘20 JT
I think training people to use it properly is a better answer. That way it can still be used when appropriate.
pixeldecals
Chicago Area, IL
www.pixeldecals.com
I don't disagree with you however it's always nice to have options because different people like different things.
roaniecowpony
Retired Engineer
The daughter is still likely to change the temp setting to her liking. That would require resetting.
Maverick909
Inland Empire
www.instagram.com
anytime you adjust the dial for the passenger side it will unsync the system until you hit the sync button again. This is the same with my chevy P/u and my coworkers ford pickup.
