Goin2drt
@DanW
For one, the timing with disable ESS has been fixed. ESS turns off in say 3" versus the 10 or so seconds with the older firmware.
Also, with 11.0.6 no one using same has reported ESS not being disabled each and every time. Myself and others with past firmware had ESS occasionally not disable with each start. Not the case for me. When using .3 my ESS worked perfectly and now it doesn’t. This is the main function I am using right now.
Disable auto park works well with 11.0.6 . Note: Seat belt has to be fastened for disable auto park to work properly
With older firmware, a couple of features were lets call it stepping on each other ...11.0.6 those issues have been fixed.
Anyway, while not perfect, 11.0.6 is the pick of the litter firmware wise!
Yes, Turncam still needs tweaking so just don't use it, if you do not want to deal with the occasional hiccups that it has. Probably next firmware release there will be less or no quirks with that terrific feature.
