Tazer JL - more than just a tire size programmer!
Status
Not open for further replies.
Howi
Cheshire, UK
Jeep Wrangler JL 2019
Another issue
brake hold
#1
it works but throws up an ABS fault ?
#2
doesn’t work if brakes on as you are stopping then brake hard, need to lift then brake hard
#3
Also if ESS is on this is the sequence;
Brake hard >2secs
Engine off
Brakes on
foot of Pedal
Engine starts
so the last bit you don’t want until you hit the gas again.
Jeep Wrangler JL Tazer JL - more than just a tire size programmer! 437B7E24-A90F-470A-B18F-06E428BF8F90
coachgrinnan
Michael
Austin TX
2018 Jeep Wrangler JLU
Another issue
brake hold
#1
#2
#3
Brake hard >2secs
Engine off
Brakes on
foot of Pedal
Engine starts
This happened to me yesterday in a a drive through. I just updated it. I was sitting waiting for my food, and stretched, I pressed the brake in a bit harder. The back lot up like a Christmas tree. Reading this I now know what happened.
DanW
Indiana
The back lot? Typo? Did you mean brake light?
DanW
Indiana
Howi
Cheshire, UK
Did it quit doing that when you turned off the feature?
it resets once you drive off so it does work.
the bit wrong is the ABS fault lights up. (and presumably logs in the event file?)
Have emailed Z automation and pointed them at this thread but....... :(
Howi
Cheshire, UK
Another issue
brake hold
#1
#2
#3
Brake hard >2secs
Engine off
Brakes on
foot of Pedal
Engine starts
not getting any response on this, have asked on the official site as well?
anybody know Joe to give a little prod?
joe@zauto
joe@zauto
Commack, NY
2018 wrangler rubicon unlimited
The ABS fault message I tried to blank but the instrument cluster wont let me. It's not in fault state; its a temporary diagnostic mode where I'm able to hold brake pressure. No harm, any ABS command will flag that warning. There is no event log for diagnostics so nothing is saved there.
As for ESS, when the engine is off and I send an ABS command, the Jeep starts; I don't have a way around that either currently, and I can't try to get around it as I don't have a test Jeep with ESS (I have a 392 and a 4XE)
Howi
Cheshire, UK
cheers Joe, have ESS turned of now so no biggie.
Overkill
Michael
Paris, IL
www.camaroheaven.org
2019 JLU Rubicon; 2018 JLU Sahara; 2002 TJ Sport; 2005 GMC 2500HD; 1969 Camaro (blue); 1969 Camaro (red); 1974 Chevrolet Cheyenne K20
Information Technology
I had my 2.0 BSG Rubicon lose pedal a couple of times where the pedal went all the way to the floor. So, I turned the feature off because that was a little scary to me. Is that normal also or am I the only one that has had that happen? I liked the feature, but the dash lights combined with the pedal going to the floor made me fear it would damage the Jeep.
joe@zauto
joe@zauto
Commack, NY
Brake hold, when active, holds pressure to the brakes while relieving pressure when you apply them; which makes the pedal feel “soft” while the ABS system holds the brakes for you. Since the valves are holding fluid pressure to the calipers and blocking pedal pressure, the pedal fluid has nowhere to go so has to be relieved
Howi
Cheshire, UK
it has let go a couple of times , which is a bit worrying!
shellback
CNY
2020 Rubicon Unlimited
Recently purchased a 2020 Rubicon 3.6L (Auto) and it has the Tazer Mini installed, firmware 11.2.5
Just starting to learn about the Tazer and the settings but the gear ratio threw me off. I believe it still has the stock 4.10 gears, but not sure how to verify.
What are the pros/cons of changing the gear ratio? Mine was set at 4.88 (Low 4.00)
I need to verify the actual tire measurement as well, setting 35.51, with 37" Mickey Thompsons.
When I go by the auto-radar speed traps the speedometer is only off by about 1 mph so possibly the settings are correct.
Other settings: Locker both, Front axle disconnect NO, Sway bar yes.
I'm sure it's been covered before, but hoping for a quick answer or a point in the right direction, rather than searching and reading for hours.
DanW
Indiana
Do you know the previous owner? You will want to leave the low range ratio alone. It is correct. You need to determine if the previous owner changed the rings/pinions. If already set at 4.88, then I'd bet that's what is in there. But you'll want to be sure before messing with that ratio on the Tazer.
We can figure it out if you have no way to contact the previous owner. Just tell us the transmission, tire size, and rpm at a set highway speed in top gear, say 70 or 75mph. Verify the speedo is accurate by using your phone, too. That'll be critical. If you have a manual transmission, I'll be able to help easily. If an auto, we'll defer to someone here with an auto and same size tires, same gear, same speed.
shellback
CNY
I don't know the previous owner, unfortunately. It was a trade in at a dealer.
It's an Auto transmission, Mickey Thompson 37" tires (measured at 35 3/4"). I'm taking a run in the Jeep in a few and will see about RPM and speed.
The speedometer does seem pretty accurate when comparing it to highway radar signs that flash your MPH.
Thank you! Really appreciate the help!
Status
