KansasJL
The Tazer mini should be marketed as the Tazer 2.0. It’s one piece instead of two and it installs under the dash for a clean install. They both do exactly the same thing.
Thank you so much I will do the update and see what happens
@DanW fair enough. I’m honestly not sure what vapor lock is. But does it also explain the power steering?I installed the Tazer and a couple days later, it rained on me with the top down. That never happened before I installed the Tazer, either.
All joking aside, of all the posts here and on other forums I've seen about issues with the Tazer, I've never read any issue even remotely like this. You probably experienced vapor lock or something like that. It is rare in modern cars, but can happen and could cause something similar to what you experienced. There's just no way to tell.
I've been running the Tazer for probably around 20k miles. Any quirks I've experienced were not unique and had been reported by others.
Vapor lock is like an air pocket that can get in the fuel system and can cause a vehicle not to start for a bit. Usually modern vehicles are not susceptible to it, but under perfect conditions it can happen. The power steering is odd. I'm not sure, but I think the PS system is a hybrid with both hydrolic and electric boost, but I'm not as familiar with it.@DanW fair enough. I’m honestly not sure what vapor lock is. But does it also explain the power steering?
Dan, what version of the firmware do you run? I’ve had my Tazer in use for 13 months, now, and agree with 99% of what you’ve written. However, I did get bitten in the ass by trying a beta version last winter. It was an eye opening lesson. A malicious device or a nasty bug in a trusted programmer could really eff up these vehicles, and I came to realize that the “secure gateway module” is not just a way for FCA to make money adjusting speedos. (It’s mostly that, though.)Vapor lock is like an air pocket that can get in the fuel system and can cause a vehicle not to start for a bit. Usually modern vehicles are not susceptible to it, but under perfect conditions it can happen. The power steering is odd. I'm not sure, but I think the PS system is a hybrid with both hydrolic and electric boost, but I'm not as familiar with it.
I can tell you that my JL has had hiccups with the Uconnect system without the Tazer. In fact, it has more issues without it than with it, or at least it seems. Also, my ESS has had a couple times where it wouldn't start the engine as a light turned green. After shutting the Jeep off, it restarted but then the ESS was disabled until I stopped and let it sit for a few minutes completely off. It did that without the Tazer, too but hasn't done it with. I don't think the Tazer cured any of that, but rather it just points to the complexity of the entire operating system. One thing the Tazer does allow me to do is reboot the Uconnect, which usually cures its quirks for a good while.
Do you have the 2.0 with BSG or 3.6? I'd imagine the 2.0 is even more complicated. I am alsu unfamiliar with the power steering system on the 2.0. I'm not sure if it is common with the one on the 3.6, or not. The auto tranny probably adds complexity, too, as it is electronically controlled. (Mine is a manual)
I'm also assuming your Jeep didn't thow any codes when it stalled?
I really didn't mean to make light of your situation. I can be a real clown and sometimes can't resist trying to be funny. Please take it as a reminder not to take me too seriously. I hope your Jeep is well and just had a hiccup.
I'll have to check. I think I'm 2 back on the firmware because it was doing everything I wanted. I'm planning on updating either tomorrow or one day this week, though.Dan, what version of the firmware do you run? I’ve had my Tazer in use for 13 months, now, and agree with 99% of what you’ve written. However, I did get bitten in the ass by trying a beta version last winter. It was an eye opening lesson. A malicious device or a nasty bug in a trusted programmer could really eff up these vehicles, and I came to realize that the “secure gateway module” is not just a way for FCA to make money adjusting speedos. (It’s mostly that, though.)
Anyway, my point is that it’s not crazy to think the Tazer caused his issue. Firmware builds newer than 11.0.6 have a lot more features (which means more opportunities for bugs). The 11.1.4 instructions even warn that a stall condition is possible after changing settings. It says to wait 10 seconds before retrying and that it’ll go away.
I have been on 11.0.6 most of the time because of my bad beta experience, and because 11.1.2 had unreliable ESS disablement. I just upgraded to 11.1.4 on Monday and so far so good. ESS seems as stable as it was back in 11.0.6, and I’ve had no problems whatsoever with any of the other features. The reason I upgraded was to take advantage of the parasitic draw bug fix that was done last winter. I’ll not be upgrading, again, without a compelling reason.
@DanW Thank you for explaining vapor lock. I can’t say for certain it wasn’t that.Vapor lock is like an air pocket that can get in the fuel system and can cause a vehicle not to start for a bit. Usually modern vehicles are not susceptible to it, but under perfect conditions it can happen. The power steering is odd. I'm not sure, but I think the PS system is a hybrid with both hydrolic and electric boost, but I'm not as familiar with it.
@DanW I never answered your questions:Vapor lock is like an air pocket that can get in the fuel system and can cause a vehicle not to start for a bit. Usually modern vehicles are not susceptible to it, but under perfect conditions it can happen. The power steering is odd. I'm not sure, but I think the PS system is a hybrid with both hydrolic and electric boost, but I'm not as familiar with it.
https://www.zautomotive.com/zpu/instructions/TazerJLUserGuide1114.pdfThe last manual posted is from 11.0.8 They should at least post a new manual to explain the new features.
