Tazer JL - more than just a tire size programmer!
Status
Not open for further replies.
Euro JEEP
Stefan
Spain
Jeep TJ
Can the Tazer solve the shortcomings of the one-touch down and up window buttons front and back?
I believe the JL only comes with one-touch down window for the front? Not up nor no one-touch buttons for the back at all.
Rhinebeck01
Multiple places..
@Euro JEEP
Your answer is no.
Euro JEEP
Stefan
Spain
Jeep TJ
Too bad...
Is that a hardware or software issue?
bzaps914
Brandon
New York
Wrangler JLUR
For those with the LED upgrade package....Is there any way to leave the taillight “jerrycan/hourglass” outside LED on with the DRL’s?
OldGuyNewJeep
Don
CT
No
DanW
Indiana
BostonBilly
Billy
Mass
2015 JKU
Sure, just ask @joe@zauto. I think he's always looking for suggestions.
I did that to ask about "lockers anytime and brake light flash". Joe is pretty good about responding that he will look into it or that it can't be done
DanW
Indiana
I'd LOVE to have the brake light flash. I think that's a great safety feature to help with cell phone distracted drivers following behind you. It increases the odds of your brake lights waking them up enough to get them to stop or go around.
Pavementfree
2018 JLU Rubicon, 2017 WJ2 75th, 2011 F3shitty, 2006 Seadoo GTX sc
Firefighter
Perf menu:
Adjust for alternate tire sizes up to 41″
Adjust for alternate axle gear ratios
Adjust for an alternate transfer case LO range ratio
TPMS menu:
Disable TPMS system if desired
Change front/rear TPMS warning PSI limit
Radio menu:
Disable Backup camera
Enable Cargo/front/uncercarriage Camera input
Enable CD audio input
Disable TravelLink (weather warnings included)
Lighting Menu:
Change DRL region (type)
Change DRL location
Disable DRL Dropout
Enable Fog lamp output
Disable Fog lamp dropout
Disable Halo’s
Set LED 3rd brake light type
Set LED tail lamp type
Set LED front turn signal type
Set Trailer Tow output for use with Mopar kit
Other menu:
Disable/Enable Electronic sway bar – for axle swaps or to run disconnected at any speed or drive mode
Disable/Enable Front Axle Disconnect
Disable/Enable Front and Rear Lockers
Enable Aux switch settings on the radio
Enable Blind spot detection (sensors required)
Change cluster splash screen to Wrangler/Sahara/Rubicon
Live features – these run only while the tazer is plugged in:
Light shows (Patented): Can be accessed from the key fob or from the on-screen menu. 6 pre-set light shows and 3 make-your-own shows included. Set from the factory to only operate when parked, but can be unlocked for off-road and emergency personnel use.
Disable Navigation in-motion lockout – enter addresses while the vehicle is moving
Disable camera lockout – use the backup camera and/or added cargo/front/undercarriage camera at any speed for any length of time
Auto Traction Kill – can be set to turn off traction control upon start-up
Auto StopStart Disable – can be set to disable AutoStopStart upon vehicle start-up
0-30 and 0-60 timers
Cooldown mode – run engine fans when Jeep is off, to aid in cooldown
Winch mode – raise engine idle to 2000 RPM while winching or jumping another vehicle
Line Lock - Want to do a crazy burnout in your Jeep? Probably not, but if you did, this function will lock just your front brakes, allowing the rear brakes to remain off for easy burnouts.
Rock Crawl - press 2 buttons on the steering wheel and this will hold all four brakes for you - perfect for rock crawling/off-road with manual transmission Jeeps, or even for starting out on a steep hill. No need for the parking brake or heel-toe in these situations, let your fingers do the braking. Patent Pending.
In reguards to the rubicon's lockers, will this allow me to engage my rear locker in anything other 4 low? There are plenty of times I want a locker engaged and don't want 4 low. Hell my F-350 lets me lock the rear in 2wd.
Thanks and I'm sorry if this is already covered but I could not find it.
Rhinebeck01
Multiple places..
For those that will be buying a Tazer JL or Tazer JL Mini..
For 5% off, this code will still work. I verified that it will, tonight: JeepInformant2
The code will not work for the Tazer JL Lite. It will work for the Tazer JL and Tazer JL Mini.
Suggest you buy here:
https://zautomotive.com/product-category/tazer/
Note: When you purchase, consider going with the two year warranty that costs $20 versus the free 90 day warranty. Just click on where it says "90 days - Free" and you can then select 2 year warranty.
By the way, I have nothing to do with ZAutomotive. I'm just a real happy TazerJL Mini user..
aug0211
Ohio
JLUR 4xe
Haven't checked in for a bit, because things had gone stagnant.
Last time I brought this up, I was told it was because Joe was 100% focused on getting stuff ready for SEMA.
Has anything new happened with TazerJL in the last couple of months? Or is development dead?
joe@zauto
joe@zauto
Commack, NY
2018 wrangler rubicon unlimited
Definitely not dead!! Just trying to iron out a big before releasing the next firmware. Some are hard to find... but I’ve been working feverishly on trying to get this next version out!
islandtees
gary
florida
2018 rubicon jl
The 11.07 beta, when will that become an official release?
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
I’m waiting on 11.08 :like:
Status
