Tazer JL Mini Refurbs
BadAssBumbleBee
Richmond Hill, Ontario
2019 Jeep JL Rubicon, 2010 Callaway SC572 Camaro SS
I got my refurbished Tazer JL Mini and SGW Extension Cable today. Apart from a few minor scuffs, the Tazer looks like new :)
I'll get it married to the Jeep on the week-end and make sure everything is working as it should.
Chupacabra
Greenville, SC
2021 JLU
Thanks for the heads up, that’s good to know. However, my wife will 100% screw that up so I will leave it off for now unless I have a trip out to the boonies where Google Maps doesn’t have service.
FYI - if you know you're going out to the boonies, you can download Google maps in advance for that area so it'll still work without any cellular/wifi coverage.
Multiple places..
There was a forum thread started on 3/27/21 that is entitled...
"Refurbished Tazer reported not compatible with JL"
https://www.jlwranglerforums.com/fo...-tazer-reported-not-compatible-with-jl.68860/
Can tell you that the info in that thread is absolutely wrong in regard to the Tazer mentioned being incompatible.. The fact is, it is compatible.
Suggest that the guy posting the pure crapola in that thread, reach out to Joe again.... so Joe, can get him up to speed on this..
Again, do know that in fact the refurbed, Tazer's that were being sold at ZAutomotive's website (none avail. presently, but will be again) are in fact compatible with the JL and JT. and you can save lots of $ buying one and doing the following...
Just know that when you get the refurb, you will must use the ZPU Utility, and with "Recovery Mode" , reflash the Tazer refurb with the most current firmware for the Tazer JL. That is it.. Is very easy to do and only takes a few minutes... and yes, you need to also have purchased the necessary bypass module from ZAutomotive to use with the Tazer.
Multiple places..
Forgot to mention in the last post....
If interested in a refurb, DO, check these links on occasion... 8-)
https://www.zautomotive.com/product/refurbished-tazer-jl-mini/
https://www.zautomotive.com/product/refurbished-tazer/
Remember you also need to buy the ZAutomotive, SGW bypass module , along with this particular Tazer, if you want to use the with a JL or JT...... and remember, that when you get this particular refurb, you will must use the ZPU Utility, and with "Recovery Mode" , reflash the Tazer refurb with the most current firmware for the Tazer JL before you install on your JL or JT.
OldGuyNewJeep
Don
CT
The original two piece Tazer absolutely is compatible.
I think old Rahneld (who renamed himself like three times) is eating too much of this:
Jeep Wrangler JL Tazer JL Mini Refurbs 1616963553576
Multiple places..
Multiple places..
If we have a 4xe do we just select the 2.0 version?
@smack2006
Joe's site just asks you what vehicle you have for their records so to speak...
A Tazer JL Lite or Mini or Original Tazer JL, will work on any and all JT and JL's.... to include your 4xe.
With that said, just order, the site does not yet have 4xe listed yet, so click on 3.6 or 2.0, etc..
HINT... big hint.... Do also order the SGW Extension Cable along with your Tazer JL.
@joe@zauto
FLTrailRider
2021 Rubicon 2dr
Some Dumb questions on how this works
Does these need to keep plugged in all the time for it to work, or do you plug it in, flash the vehicle and remove it?
What are those extension wires for and where does this plug in?
If you left this plugged in could it void your warentee at a dealer visit?
I want to change some settings.
tire size 35"
tpms range for tire psi
auto start memory
fog light control
nav adjust goto when in motion
Ospreyfe55
Marc
Navarre, FL
2020 Jeep JLU Rubicon
tire size 35"
auto start memory
fog light control
For some items the Tazer will need to stay connect. Most of those are for the live features, but the adjusting tire size, gears, etc can be adjusted and then the tazer be disconnect but stay married. I just leave mine connected so I can access things like lockers and swaybar disconnect when I need it.
zrickety
Technician
I have a question, already did a search for it, think I know the answer.
Does the axle locker control (Rubicon) override any of the sensor errors? Or is it simply bypassing the 4LO requirement?
GATORB8
CLT NC
21 JLURe
7/21
Joe at ZAutomotive has plenty of,
Refurbished Tazer JL Mini's ON SALE right now.
Sale Price is $265.00 ... (Limit 1 per Customer)
Warranty 90 days but you can buy a 2 yr. warranty for $20.
The original 2 piece Tazer is also avail... ($165.00) to use you will need to also purchase a bypass module ($25 -$69 depending on the brand you buy) and load the correct firmware. This gives you a 2 piece Tazer JL which does the same as a Tazer JL Mini... but yes it is a two piece affair..
Ordered, thanks for the heads up.
Multiple places..
7/27/21 Tazer Mini Refurb's SOLD OUT
7/27/21
STILL AVAILABLE
