Scarabmike
- Miguel
- Aug 28, 2018
- Jacksonville, FL
- 2018 JLU
- Vehicle Showcase
- 2
Damn just missed it!
FYI - if you know you're going out to the boonies, you can download Google maps in advance for that area so it'll still work without any cellular/wifi coverage.Thanks for the heads up, that’s good to know. However, my wife will 100% screw that up so I will leave it off for now unless I have a trip out to the boonies where Google Maps doesn’t have service.
The original two piece Tazer absolutely is compatible.Suggest that the guy posting the pure crapola in that thread, reach out to Joe again
@smack2006If we have a 4xe do we just select the 2.0 version?
For some items the Tazer will need to stay connect. Most of those are for the live features, but the adjusting tire size, gears, etc can be adjusted and then the tazer be disconnect but stay married. I just leave mine connected so I can access things like lockers and swaybar disconnect when I need it.Some Dumb questions on how this works
Does these need to keep plugged in all the time for it to work, or do you plug it in, flash the vehicle and remove it?
What are those extension wires for and where does this plug in?
If you left this plugged in could it void your warentee at a dealer visit?
I want to change some settings.
tire size 35"
tpms range for tire psi
auto start memory
fog light control
nav adjust goto when in motion
Ordered, thanks for the heads up.7/21
Joe at ZAutomotive has plenty of, Refurbished Tazer JL Mini's ON SALE right now.
https://www.zautomotive.com/product/refurbished-tazer-jl-mini/
Sale Price is $265.00 ... (Limit 1 per Customer)
Warranty 90 days but you can buy a 2 yr. warranty for $20.
The original 2 piece Tazer is also avail... ($165.00) to use you will need to also purchase a bypass module ($25 -$69 depending on the brand you buy) and load the correct firmware. This gives you a 2 piece Tazer JL which does the same as a Tazer JL Mini... but yes it is a two piece affair..
https://www.zautomotive.com/product/refurbished-tazer/
