Tazer JL Mini and Winch Mode -- Won't Cancel
PJRider
Patrick
Austin, TX
JLUR
Have the Tazer JL MIni with 11.1.1 on a 2019 JLU.
The Winch Mode setting (press left arrow and cruise RES at same time) that holds RPM's at 2000, I cannot consistently get it to stop. The documentation says that "It will NOT raise if you touch the accelerator pedal, and will cancel if you do."
I read this as touching the accelerator will cancel the winch mode hold. One time it worked after multiple attempts -- with me stepping on the accelerator -- 3,000 RPM, etc."
Another time I couldn't get it to cancel and just turned the engine off.
Is this by design or should it cancel. And, happy to flash to newer version but before I did wanted to know if this is working as intended.
Thanks.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
I found that winch mode was a tad flaky, not a lot but on occasion would not shut down
  • Like
Reactions: J0E
StingJL918
Eduardo
Marengo, IL
2019 JLU Rubicon 2.0 StingGray
ICU Nurse
Thanks.
To access and use the winch more does the Jeep have to first be off like when you set the tpms? And then you turn on? Or how does it exactly work. I wish there was more videos online showing the features.
