Tazer JL Lite - $219 - Terrific New Product Offering!
Jeeper
Acura MDX 2015, Ford F150, Honda Odyssey,
When you go in for service, is it simply a physical disconnect or do you just "unmarry" and leave it up there? Do you have to reset everything again each time? Is it a pain to pull of the panel each time for the service disconnects?
Rhinebeck01
Rhinebeck01
Multiple places..
Easily
@Jeeper
The plastic panel that needs to removed and replaced is so very easy to remove and replace. What will take a little bit of effort is the removal and reinstall of the Tazer JL or Tazer JL Lite hardware. You remove the plastic panel to facilitate this hardware removal.
Just before you go to the dealership service department visit:
(This will take you 10 min. +-
Do not even consider going to a service department appointment unless you do the following!
  1. Easily, remove plastic panel (optional)
  2. Unmarry Tazer JL or your Tazer JL Lite from your JL
  3. Disconnect / Remove all Tazer JL or Tazer JL Lite hardware
After dealership service department visit:
(This will take you say 10 min. +-)
  1. Re-connect all Tazer JL or JL Lite hardware
  2. Easily, replace the plastic panel
  3. Remarry Tazer JL or Tazer JL Lite to your JL
  4. Re-program anything that did not automatically migrate back to your JL (Most programming will )
Jeeper
Easily
@Jeeper
I'm just curious, what would the consequences be? Does this immediately void a warranty? Obviously, I'd do all the steps you outlined but I'm still curious about the consequences.
Jeeper
Different question, in what sort of situation would you adjust the "gear ratio" with the Tazer product?
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Only if you physically regear, so if you don’t put in new gears leave these settings alone
Gadgetguru
Pennsylvania
2018 Jeep Wrangler JLU Sahara
I'm sure this has been covered in the boat load of Tazer threads, but do I need a laptop to change settings with the Tazer JL Lite? Example, to raise engine rpm for winching, it would be inconveinent to have to have a laptop with you all the time. Or is this able to be changed via the touch screen? Also, can anyone confirm there is no military discount for the lite? Still debating on the Tazer Lite or Superchips. Just need it for tires and gears and the new tires and wheels come Tuesday. Need to get one quick. Thanks.
Bingy
Bailey, Colorado
2018 Jeep Wrangler Sahara JLU
No laptop needed. You utilize the dash by way of the buttons on the steering wheel. Not sure on discounts.
Gadgetguru
Pennsylvania
Thanks! I stopped being lazy and went to their website (duh!) and read the instructions. LOL Looks like some combo of cruise control buttons.
Rhinebeck01
Rhinebeck01
Multiple places..
@Gadgetguru
Yes, to update the firmware on the Tazer JL or Tazer JL Lite you do need either a Mac or PC. Can be a desktop or a laptop.
No, no laptop necessary inside the JL, while driivng, etc., in order to use any feature to include winch mode.
All features are dealt with .... toggled on and off, enabled or disabled, via the evic (readout)screen on your dash.
Tazer JL Lite is already paired down price wise, so no, no military or forum discount on same.
Military or forum discount is avail on the Tazer JL.
Do your home work before purchasing a programmer!
In relation to other brand programmers, ...Most here, per the forum poll, have gone with a Tazer JL ... and now, more it seems, are going with the Tazer JL Lite.
The Tazer JL Lite can be enabled to a full Tazer JL, if in the future, (for $125) you want the full Tazer JL feature set.
Carlton
Chicago
Jeeps lots of jeeps
Easily
@Jeeper
What if you regeared the jeep? It won't run if you remove the programming. It will go into limp mode.
joe@zauto
Commack, NY
2018 wrangler rubicon unlimited
It’ll actually only throw a “Service AWD” if you put in in 4 low on a rubicon. Otherwise your speedo will just be off.
The old JK is a fdiffeeent story. That would go into limp mode
Or don’t unmarry it - or unmarry to wipe all other settings, remarry and change the gear ratio...
Beowulf
Jeep Wrangler Rubicon Unlimited
I’d like to see two TPMS settings. One for 2h and one four 4low
WranglerMan
Will
Katy Texas
Gas Pipeliner
@joe@zauto this question is totally off topic but I am curious what happens if say my Tazer became damaged beyond repair and I had to get another one with the previous one already programmed to my Jeep, how would th new Tazer marry up ?
RamenLife
Joseph
Las Vegas
2018 JLU S
Easily
@Jeeper
I just upgraded my wheels and tires for 33” on 17” wheels on JLU Sport S and I am curious about that I need to program to put 33” tires on computer?
If I do, then I want to use Tazer JL product.
Do we need to disconnect even we going for regular maintain services as well? Like oil changes? Sorry This is my first Jeep and I am new to modifying.
