How long does it take for the Jeep battery to deplete?@ar15rifle
And you also see this > "Voltage at 14.0-14.7 all of the time." ??
When I had my Tazer JL and Tazer JL Min (I have had both) installed, the JL always ran voltage at 14.0-14.7 all of the time. I had a battery depletion, one time requiring that I jump start the JL.
Anyway, removed the Tazer about 4 weeks ago and have driven 4,000 mi. +. Not once has the voltage reading gone above 13.5 per 8.4 radio, Off Road Pages, display. I monitor closely.
This alone, tells me something is a muck lets say. I do not need to monitor my JL with a voltage meter to know this.
I was running 11.0.6 firmware. The issues, happened with the Tazer JL and the Tazer JL Mini.
My Tazer JL Mini is unmarried, and is still sitting in a drawer in the garage. I can't risk getting stranded due to battery depletion. Yes, I miss using the Tazer JL Min, Live Features, but ..............
I have the 2 piece Tazer original. I have not upgraded from version .03 because the upgraded versions are having to many problems.UPDATE: unplugged the Tazer from OBD but left it married. Battery now charging 14.1 -14.3v all the time while driving. No more battery issues. Mine would stay at 12.7 while driving and go to 13-14v when hitting the brakes. But when start stop would engage, battery would go down below 11v. There is definitely something wrong with the Tazer plugged in that is messing with the charging system. Keep an eye on yours.
@Huehue80Are all these problems happening on the 3.6. I have a 2.0 turbo and have ran the Tazer original since September. Updated the firmware everytime a new one came out. Zero problems with the battery. The only thing I don't use is the turn cam, it's to distracting while driving. Anyone on here having problems with the Tazer and 2.0 turbo? I have turned off travel link to get rid of weather alerts. I use the Tazer for tire size, and locker features, in motion to use the touch screen while moving. I'll be installing gears soon.
Same thing for me exactly! But sometimes mine does go to 14.6 After sitting for two or three days!I have the 2 piece Tazer original. I have not upgraded from version .03 because the upgraded versions are having to many problems.
I have left it in the port and removed it. Still married, I get 14.1-14.3 either way. I have not had a battery drain. So these problems must be the new firmware versions or the newer single units.
^ Ditto, though I’ve not taken as many samples as @WranglerManBeen doing battery voltage tests for the past couple weeks and honestly have seen no huge issues but who knows what is causing battery issues, maybe a conflict with Uconnect and Tazer or some setting but time will tell, currently my Tazer is married and I changed a few things and now just gonna run with it and see what happens and use I have cables
Keep in mine, it was fine for a while, then one day, battery dead. Then I started monitoring the voltage and knew something just wasn't right.^ Ditto, though I’ve not taken as many samples as @WranglerMan
I’m leaning toward the idea that it might be an issue only with minis, or only with autos with auto park feature on, or maybe some other live feature that I don’t use (in motion, perhaps?)
Anyway, time will tell. Until then, I’m not losing sleep. I’ve had 6+ months and 10,000 miles with my Tazer and my battery hasn’t left me stranded, yet. This thread did prompt me to get a trickle charger, though, and I’ve used it on all three of my vehicles to top them off cuz why not?
Edit: I’ve been on 11.06 since it went GA. I’ve no intention to upgrade without a compelling reason.
From chatting with a few techs at the local dealer the voltage is supposed to swing and what you are seeing displayed in the EVIC is what the alterantor is sending to the batteries so in your case the 14+ volts are constantly being sent to the batteries so either the IBS is bad and can not detect the correct voltage or your batteries are in fact low or bad deeming that they be charged at the heigher rate which will shorten there lifeUPDATE: unplugged the Tazer from OBD but left it married. Battery now charging 14.1 -14.3v all the time while driving. No more battery issues. Mine would stay at 12.7 while driving and go to 13-14v when hitting the brakes. But when start stop would engage, battery would go down below 11v. There is definitely something wrong with the Tazer plugged in that is messing with the charging system. Keep an eye on yours.
Yeah I've heard that too, but a normal car charges their batteries at 14v when the vehicle is running. I wouldn't say that's over charging. Needless to say constant 12.7 with all accessories running while driving doesn't seem right. Also dropping below 11v at start stop also is not right. All I know is mine seems to be working well now without the Tazer live plugged in .From chatting with a few techs at the local dealer the voltage is supposed to swing and what you are seeing displayed in the EVIC is what the alterantor is sending to the batteries so in your case the 14+ volts are constantly being sent to the batteries so either the IBS is bad and can not detect the correct voltage or your batteries are in fact low or bad deeming that they be charged at the heigher rate which will shorten there life
