WranglerMan
- Will
- May 8, 2018
- Katy Texas
- 2018 Wrangler JLU Sahara
- Occupation
- Gas Pipeliner
- Vehicle Showcase
- 1
Ok Gentlemen here we go,
Rather than try the remember all the places I have posted questions and comments on using a Zautomotive Tazer with my JL it’s much easier to start right here and post my testing results.
To sum things up my voltage spiked to over 14 and stayed there and ESS was inoperable as it stated battery was charging and after the battery was tested on a GR8 tester it failed and was replaced under warranty.
I can pinpoint my voltage jumping shortly after putting the Tazer in and using both vehicle and live features of the Tazer but cannot and will not say the Tazer caused it and it was maybe just a crappy factory battery.
For the next several weeks I will be reporting on my voltages now that my Tazer has been remarried to my JL and will slowly start using more and more of the Tazer features
After getting my JL back from service I left the Tazer in storage and ran all factory even though my speedo was not right due to larger tires, I have been running with it that way for almost a month and everything has operated normally with no error messages or erratic behavior and ESS has worked perfectly
My voltages have been very consistent with no Tazer and after getting it back I put it on a trickle charger so I knew I would be starting with a solid voltage and after pulling it off the charger the battery voltages at these three points were 13+ ( main, N1,N2 ) seeing above 13 is common coming off a charger and usually within a few hours it settles down and it did as voltage was 12.6-12.7 at these three points and idle running voltage was 12.6-12.8 in the EVIC and running down the road voltage would vary from 12.6-14 depending what i was doing and as I have said it only ramps up to over 14 when slowing down or braking and normal rolling down the highway it’s in the 12.6-12.9 range and as I mentioned in others posts when mentioning this to the service folks they advised that’s normal for smart charging
Well yesterday I put it on the tender again and got the same voltages right after coming off the tender and again an hour or so they were back down, I then married my Tazer and will document below what voltages are over the next several weeks runnig the Tazer
Test Info:
Auto trans
3.6
650 amp battery and standard alternator, all voltages are in the following order, Main batt, N1, N2, EVIC display
Tazer JL firmware 11.06
Klein MM400 multimeter for checking voltages
Deltran battery tender plus was used for the initial trickle charge to 100% charged.
Day 1
Tazer was married and tire size was set and TPMS limits were adjusted then Tazer was unplugged
After tender, resting voltage
13.09 main
13.08 N1
13.08 N2
12.7 running idle and no ramped voltage
About an hour or so coming off charger resting voltages are:
12.67
12.67
12.65
12.6 at idle
Voltage ramps to 14+ when slowing down or braking
Test Info:
Auto trans
3.6
Day 1
13.09 main
13.08 N1
13.08 N2
12.67
12.67
12.65
12.6 at idle
