Tailgate Panel - Green Retaining Clips
18BlackJLRU
Daniel
Montréal, Québec, Canada
2024 4XE Rubicon
What is the Mopar Part Number for the Green Clips that holds the tailgate panel in place. Are they available elsewhere than from Mopar.
Thanks,
Daniel
Rhinebeck01
Multiple places..
@18BlackJLRU
Can tell you that you will play hell trying to find those green clips anywhere.
Only way I found you could buy them, is if you bought the rear tailgate panel at about $100, just so you can pull the 10 or whatever the green clips off of it.
Anyway, I looked everywhere. Called multiple dealers. I needed just one green clip.
My solution.. I talked to a local dealer and I was allowed to remove 2 green clips from a JL that was being returned to FCA under the Lemon Law... Dealer did me a solid! :rock:
If you find a source where you can buy the green clips alone, do post here where, as many here will appreciate your info.
18BlackJLRU
18BlackJLRU
Daniel
2024 4XE Rubicon
Yep that’s exactly what the dealer told me this afternoon, the clips were not sold separately, they only came with the tail gate panel... It doesn’t make any sense... it would make great sense to only replace the ones that breaks... Me too I only had one that bore off !
StuartR
Stuart
Las Vegas
2020 Wrangler JLU Diesel
DOCXKT
NEW YORK
2018 JEEP WRANGLER JL UNLIMITED SAHARA
My car is at the dealership now cause one of those clips doesn’t sit well inside the groove and rattles.
Mojito!
E TN
2018 Sahara Unlimited JL
StuartR
Stuart
Las Vegas
As far as I know a JL is a JL. 2018 has two models within the same year so if yours is a 2018 JK then they probably won't fit.
If it is a JL then it should fit.
Mojito!
E TN
I have run across some sites that don't ask for model style and automatically assume its a JK. I have been known to enter the year as 2019 to avoid that.
Thanks
sdynak
NJ
18 JLU Sahara
ashtonjarrett
Ashton
San Jose
2020 JLUR
Engineer
Just ordered a few of these after destroying a couple putting on a tire carrier. Anyone actually receive these from the link? All good?
sdynak
NJ
18 JLU Sahara
I ended up ordering from All Mopar Parts along with some other things.. received a 5 pack. It was $3.30.
