Tachometer lag/issues?
cpark92808
Los Angeles
JL Wrangler Sahara
Has anyone noticing that the RPM on the tach drops before it actually does in the engine?
I.E. when accelerating and the gear upshifts, the tach shows drop in RPM prior to the engine actually upshifting.
I am also experiencing tachymeter going up and down randomly when the petrol engine is not engaged.
The dealership is telling me that this is normal.
Anyone else noticing this as well?
greensprit
Boston
Jeep JK, 4xe on order
Yes. In EV mode I will sometimes notice the tach go from 0 to 2000 to 0 for a split second while the gear shift occurs. Doesn’t happen all the time, I’d say only 5% of the shifts will cause this. Can’t figure out why.
Sboden
Kansas City
2021 JLUR 4Xe, 2.5" lift, 17" wheels, 37" tires
I honestly don't pay much attention to the tach with automatics.
michail
Michael
2021 Sahara 4xe
I have not seen this happen. Could it be the ECU spinning the engine up and then deciding it's not needed?
greensprit
Boston
Was thinking the same. I've been trying to see if this happens with higher throttle inputs where engine spinup might be required, but I haven't found any correlation. Weird stuff.
ATO4x4
