Synergy MFG. Prototype Lift Kit Parts!!!
Status
Not open for further replies.
AllJumpStyle
CA
JL
@AllJumpStyle
is he running factory LCA for now, or did he put on the MOPAR lift LCA or another adjustable one? I tried to zoom in, but could not tell about the LCA.
Also, do you sell an extended front sway bar link that I could purchase instead of using a bracket? I would prefer to just use a link that is the correct length and not add in a bracket if possible. What length link would be needed for the 2" lift without using a bracket?
He is on factory control arms.
All of our kits will use sway bar link relocation brackets in the front as it simply works better and you can add disconnects without cutting or modifying the vehicle. On the Starter System and Stage 1, we add new rear sway bar links and relocate the stock rears to the front. The Stage 2 and up systems will include our front sway bar links with disconnects, and they will be available to purchase separately as well. They are not quite out yet but they are close.
RubiRob
Rob
Hampshire, IL
www.instagram.com
Mojave
Dang, looks a fair bit taller than my Mopar springs
Found out that photo is on 38s so not aafair compariso.
Either way just got my shipping notification for the synergy 3" coils and stackable bump stops. Pretty excited I must say!
UKCATS
DFW
2020 JLUR Recon/2020 Mazda3 Hatchback
I play piano in a whorehouse
Any pics yet of a 2 door Rubicon with your 2” coils?
cmb396
Chad
WV
2018 Crystal Granite JLUR
37x12.5 thank you!
Thanks! Can you measure the distance bt top of tire and center of underside of the fender flares?
I currently have 2.5" RC, and have been looking at Synergy due to the spring rates. Also, hows the ride? I also have the Falcon 3.3's. Thanks.
RubiRob
Rob
Hampshire, IL
www.instagram.com
Mojave
I'm in baby jail right now but I did measure from the floor to the fender if that helps. Otherwise I can get that measurement tonight when my wife gets home. The little bumps still are pretty firm with the falcons but the ride does seem nice with these springs. I won't say too much other than teraflex helped me out into getting upgraded to the new SP2 3.3s which should help with the stiff low speed compression.
cmb396
Chad
WV
Thanks. Mine with 2.5 spacer sits right at 43” in the rear with 37’s. Can’t accurately measure the from bc my inners are gone and I’m running AAL LED fender lights.
Warpath
St. Louis
2019 Wrangler 2.0T JLR 2-Door, 2020 GT500
@AllJumpStyle I installed the synergy 2" lift kit on my 2dr. I love the ride with my falcon 2.1's.
Cypher
J
AZ
Cybersecurity Leader
Are you running a spacer up front as well? looks like it rakes to the rear in the pictures, but I know sometimes it is an illusion.
Warpath
St. Louis
I am running a 3/4" spacer up front, but there is no rake. But it does look like it in that pic.
Here is another pic.
Status
