AllJumpStyle
Synergy MFG Heavy Duty Jeep JL Tie Rods and Drag links have started shipping to our dealers. If you pre-ordered, the wait is over!
8800-01 Jeep JL HD Drag Link
8802-01 Jeep JL HD Tie Rod
Our tie rod and drag link are both direct bolt-in replacements for all Jeep JL models and are compatible with stock wheels with no wheel spacers. Both components feature fully welded bars unlike the OEM crimped design and feature much larger heavy duty greaseable metal on metal tie rod ends for increased durability and strength. Both bars also feature a single plane tie rod end on one end to prevent excessive unwanted movement (flop) and to simplify installation. The bars feature pinch bolts on both ends (no jam nuts that always come loose!!!) and a double adjuster assembly on one end so the length of the bar can be adjusted without removing it from the vehicle.
The drag link includes the required flip adapter for those who will be converting to high steer (requires proper bump stop spacing and track bar relocation bracket).
The tie rod requires our 8807-03 Jeep JL Steering Stabilizer Relocation Kit which relocates the steering stabilizer above the tie rod and out of harm's way. It is compatible with stock or any stabilizer that uses 1/2" mounting hardware. We also offer our own Synergy Tuned Fox Steering Stabilizer, FOX-982-24-941.
With all the steering issues being reported on the Jeep JL, these components are easy upgrades to prevent the tie rod, drag link, and steering stabilizer from being contributing factors to steering shimmy or death wobble.
