zeroquanta
I recently swapped to the cast iron gear box and decided to try out the steersmarts brace instead. I only had this installed for 2000ish miles. This did alot to stiffen up the steering. The only reason I decided to swap was the bushing needs occasional greasing, steersmarts has a bearing. There are those that suggest the bearing will fail because of misalignment of the shaft and bearing, not sure which is better over all.
$200.00 shipped(48 lower states), all parts included.
