The 392‘s only come with 3.73s iirc, I'd say 4.88s would be more than low enough. 4.56 would be better if you do a lot of freeway driving and not much crawling. You'll be looking at $2-3k for a regear.I would think with the torque of a 392 that 4.10's would be fine (but perhaps not). It would not seem to be worth the cost of a re-gear for 4.56, so 4.88 would be the next iteration.
Yep, corrected in a later postThe 392‘s only come with 3.73s iirc, I'd say 4.88s would be more than low enough. 4.56 would be better if you do a lot of freeway driving and not much crawling. You'll be looking at $2-3k for a regear.
That should all go without saying; obviously.Weight is a minor factor compared to diameter.
Diameter is the starting calculation. Weight and contact patch together only tell you to round up to the next larger number ratio after doing the calculation.
Holy $hit I've never hesard of gears going for that much. Plenty of shops around here and they are all in the $2k ballpark.I would go with 4.56 for sure.
If you have a shop do it, I would expect to pay anywhere from $3000 - $4000, when you factor crazy labor costs.
That also assumes the original gear/tire combo was perfect.Another way to calculate it:
33" -> 37" = 12%
3.73 * 1.12 = 4.18
The tires aren't just larger, they're heavier too.
You would think. But there are a lot of people who obsess over weight like it's the only thing to factor in a gear change. Not everyone knows how gears and tire diameter relate to each other.That should all go without saying; obviously.
The XRs still came with 4.56s and 35s for the 392, which would mean 4.88s would be perfect for 37's.That also assumes the original gear/tire combo was perfect.
Given the on tap torque of the 392, I would not re-gear from 4.56 to 4.88 to move from 35's to 37's unless a large amount of weight was added and it was operating at altitude.The XRs still came with 4.56s and 35s for the 392, which would mean 4.88s would be perfect for 37's.
Agree completely, I won't even spend that money to regear our 3.6L xr from the 4 56s for 37's. It was more a comment for the OP with 3.73s that even with the 392 4.88s are the right gears for 37's in my opinion.Given the on tap torque of the 392, I would not re-gear from 4.56 to 4.88 to move from 35's to 37's unless a large amount of weight was added and it was operating at altitude.
For a 3.6 I'd do 5.13s for 37s any time.Agree completely, I won't even spend that money to regear our 3.6L xr from the 4 56s for 37's. It was more a comment for the OP with 3.73s that even with the 392 4.88s are the right gears for 37's in my opinion.
Yep... especially at altitude.For a 3.6 I'd do 5.13s for 37s any time.
I think the 3.0TD is the EcoDiesel. Is the 3.0TT the inline six big brother of the 2.0T?3.6L = 285 HP and 260 LB-FT
2.0T = 270 HP and 295 LB-FT
3.0TD = 260 HP and 442 LB-FT
3.0TT = 420HP and 468 LB-FT
392 = 470 HP and 470 LB-FT
You are correct; the 3.0TD is the EcoDiesel and I added the 3.0TT as a reference point (new Wagoneer engine). Although you **may** get into a situation that would require a re-gear, with 442 lb-ft of torque and it being a turbocharged diesel, you will notice a tire change without a re-gear far less than say a 3.6L with 260 lb-ft. The same applies to the 2.0T--you hear far less griping about performance after a tire change and no re-gear than a 3.6L owner will.I think the 3.0TD is the EcoDiesel. Is the 3.0TT the inline six big brother of the 2.0T?
Also curious about the color coding. The diesel has 3.73 gears, does that change the regear/don't regear question for those?
Edit: I re-read this thread from the beginning and I think the consensus is to regear to 4.56 on ED and 392.
