jlcolorado
I have a 2019 JLUR 6 speed with 500 miles. I'm taking it to some trails this weekend now that I think its broken in, so did a systems check on a level dirt road this morning. While in 4H I tested the sway bar disconnect which worked fine, I could hear the disconnect motor run and got the visual text notification of "Sway Bar Disconnected" on the dash screen. After driving a hundred feet I put the clutch in and shifted the transfer case from 4H to neutral and got a quick message on the dash screen displaying what I think was "Shift into 4H or 4L to disconnect sway bar". The message disappeared quickly so I'm not positive on what the message displayed. Also the sway bar button was blinking. Because of this I aborted my plan of shifting to 4L (the transfer case was in N) and shifted back to 4H and reconnected the sway bar. Once the sway bar reconnected I left it alone and shifted into 4L to make sure that was working, which it was and felt generally satisfied so quit my testing.
So my question is, should it be possible to do the follow?
I'm new to the Rubicon, but not new to Wranglers so unsure on this one and can't seem to find the answer in the owners manual or searching this forum. Thanks for the help!
- Shift transfer case into 4H
- Disconnect Sway bar
- Drive around, do some things in 4H with sway bar disconnected
- Encounter obstacle and shift into N then 4L while sway bar is STILL disconnected
- After obstacle shift back to 4H with sway bar disconnected
- Encounter obstacle and make a plan (hopefully on level ground to re-connect sway bar)
- Re-connect Sway bar
- Shift from 4H to 4L
- Disconnect Sway bar again
- Obliterate obstacle
- Reconnect Sway bar
- Shift from 4L to 4H
- Disconnect sway bar if necessary
