Sway link misalignment?
Brad41
S. Indiana
18’ JLUR firecracker red
lift noob here- I just had a jeep shop install a 2.5 RK lift with the “no limits” sway bar link on my JLUR. The passenger’s side looks different from the driver’s. Are the links supposed to be misaligned with the sway bar connected and no flex happening? Is this normal?
Driver’s side
Jeep Wrangler JL Sway link misalignment? AFBD60C1-F13E-49EB-9B9B-6529C7E5F701
passenger side:
Jeep Wrangler JL Sway link misalignment? B1690F32-2377-401D-B18C-64E64F2CA16D
Jeep Wrangler JL Sway link misalignment? F064D930-A487-4492-A96B-858C9CF7A555
rkwfxd
Rich
Whittier
Unemployed
Your front axle is not centered under your jeep.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Driver’s side
passenger side:
Just rotate the whole thing back straight, its just heim joints its going to move around like that, heims are going same direction you never want them opposite directions, then they wont move. Nothing wrong with what you got there
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
The stock links are offset because the two mounting points aren't perfectly vertical. The front offsets in, the rear offsets out. Since the RK is straight, it makes up for that difference in the joint.
As @Moto_21 mentions, the rotation looks like it's just the heims both rotating the same direction.
Mopar front and rear links:
Jeep Wrangler JL Sway link misalignment? 1649341732993
Jeep Wrangler JL Sway link misalignment? 1649341743884
Roky
Roky
Driver’s side
passenger side:
Perfectly fine, they do that, can’t be helped. It was hard for me to get used to it, but I did, lol …… way worth it when disconnected. With these links there’s no difference between hooked and unhooked. .……..
rkwfxd
Rich
Whittier
Unemployed
I hear what you are saying on that as far has the heims go, but doesn't it look like the axle is a bit too far to the passenger side?
redsyphon
North Florida
2018 JLU Rubicon
IT Project Manager
I've been running those swaybar links for 3 years now, and they've never stayed aligned. I've yet to encounter any issues when offroading or on the highway.
They're strong joints.... just tend to set off my ocd at times :)
I'd say pay attention to your Jeeps handling, etc. If you notice significant changes, then something is off. Otherwise, give the Jeep a once over every now and then, checking for changes. I'll bet you don't notice many changes with these over time :)
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
Park on a fairly flat surface and measure from tire outer edge to the fender on both sides. Should be within 3/8 inch or so. I use a 2*4 up against the tire to measure but anything long and straight works.
If not you need to adjust the track-bar to center the axle.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Both links are angled out towards the tires on axle end, if axle was really off, one side would be pulled in further than the other. Doesnt look like it is to me
Brad41
Brad41
S. Indiana
Thanks for the replies. I didn’t know the joints were designed to move like that, but it does make sense. It will test my ocd as well!
Brad41
Brad41
S. Indiana
not sure if this helps, but I took a front pic in the parking lot. I’ll take a few measurements later.
Jeep Wrangler JL Sway link misalignment? BFF396D8-2B98-4102-97E2-8EA5D48AF584
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Those springs look pretty wonky in the pics. Are the lower pads in correctly?
Brad41
Brad41
S. Indiana
I honestly wouldn’t know. Here are some more pics for you to look at.
Jeep Wrangler JL Sway link misalignment? 9BC9AD64-6DC0-4407-A1F7-D71C0C76BD09
Jeep Wrangler JL Sway link misalignment? B7F597D4-8F9A-495C-A255-9A3640BE37D4
Jeep Wrangler JL Sway link misalignment? B99500FD-2191-4E85-AF7F-3D296B03622D
Jeep Wrangler JL Sway link misalignment? AB650A4A-C8A2-47CA-AA31-CF45F9E97BBB
Brad41
Brad41
S. Indiana
Took some measurements when I got home. Within 3/8”. ??
