Swapping out TJ wheels/tires with JL wheels/tires
landshark
Alexandria, VA
2018 Jeep Wrangler JL Sport S
I have a TJ with fairly new 33" MTs (16" wheels) that I'd love to put on my JLU. And I would want to put my JLU ATs (17" wheels) on my TJ.
Has anyone swapped JL wheels/tires with TJ wheels/tires? I understand it can be done with the right spacers, but I don't know if it is a good idea. Thoughts?
WXman
Central Kentucky
2018 Wrangler Unlimited
Yeah the TJ should be 5x4.5 bolt pattern while the JLU is 5x5 bolt pattern. So you need adapters, not just spacers of course. But as far as backspacing goes, it should work out OK I think. The issue you'll likely run into is clearing the brakes on the JLU with 16" wheels. That may not work. Even my 17s are very tight.
landshark
landshark
Alexandria, VA
Ah. Good point. Thanks!
I'm leaning toward leaving the tires where they are and replacing the JLU tires with the stock wheels or ones made for the JLU. I love the tires and wheels on my TJ, but I'm thinking it just isn't worth the risk.
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU Sport
I vote no. Adapters/spacers :no:
Bestop
