AnnDee4444
Just quoting this so everyone can read it again. I've spent far too much time trying to argue this point.Ride quality you feel is mostly from the shocks, not the springs.
Gladiator also a different frame and weight distribution vehicle.I’ve owned a Rubi gladiator and wasn’t overly impressed with the rubicon suspension. What I was asking was I want something BETTER than a rubicon suspension, but I don’t want to do any kind of lift if I can get away with it.
Stock Sport springs work with a 26.25" front shock & 27.75 rear shock. https://www.jlwranglerforums.com/forum/threads/the-2dr-sport-only-thread.15647/page-20#post-1040143IF you need more suspension travel get Rubicon springs
WTF...There is no better springs when it come to comfort.
Simple enough.. MetalCloak adjustable lower front control arms and Fox performance series 2.5 adjustable reservoir shocks...(about $3K for the shocks alone).
the shocks will give you the ability to tune your ride to your preference for HWY driving, loaded carrying situations, and "wheeling". I've had King shocks on my previous JK.. they are nice too but I like the Fox setup now.
You will be able to take out that "hobby horse" ride that you can get when going over slightly bumpy roads. It is a game changer far beyond simply updating the OEM shocks. It will transform the car.
I'm loving them. I have persuaded 3 of my friends to buy the new 4xe wranglers.. and even with the extra suppose weight and stiffer shocks.. The Fox setup just kills it. If you are particular on how your jeep drives then it is the only way to go. Unfortunately you have to spend the big bucks for the adjustability. I drive in NYC/Brooklyn so the roads are crap and then out in the country (VT/CT/LI) and the improvement in handling is remarkable. (both loaded and normal) Best of luck.
You can’t fix stiff springs with any shock but you can fix soft springs with a MATCHED shock.Just quoting this so everyone can read it again. I've spent far too much time trying to argue this point.
I was giving some thought to a better shock than the MetalCloak RockSport shocks on my 3.5" MC lift. CarbonSteel has the same suspension as mine and just went to these 2.5" Fox remote reservoir shocks in a longer length and has praised them as well. We'll see how my portfolio does here in the next few months. ? ?I'm loving them. I have persuaded 3 of my friends to buy the new 4xe wranglers.. and even with the extra suppose weight and stiffer shocks.. The Fox setup just kills it. If you are particular on how your jeep drives then it is the only way to go. Unfortunately you have to spend the big bucks for the adjustability. I drive in NYC/Brooklyn so the roads are crap and then out in the country (VT/CT/LI) and the improvement in handling is remarkable. (both loaded and normal) Best of luck.
I disagree.You can’t fix stiff springs with any shock.
Lots of linear springs out there that are too stiff. Any HD 4dr springs on a 2dr.
But the 2-door has a higher front spring rate than the 4-door...Lots of linear springs out there that are too stiff. Any HD 4dr springs on a 2dr.
Guess you just haven’t experienced stiff springs. I have, and there is no shock that can soften a spring that’s already too stiff.But the 2-door has a higher front spring rate than the 4-door...
I recently doubled the spring rate in my other vehicle and increased the ride quality. How? Good dampers. And these aren't race springs either... those would have been 4x the original spring rate.Guess you just haven’t experienced stiff springs.
Funny you say that... my first hand experience says otherwise. I currently have JLUR springs on the front of my JLR. Both Jeeps are 2018 2.0 with hardtop. These springs are absolutely softer, yet they lifted the front 1/2". Because free length influences ride height too.If you put a 4dr spring in a 2dr and get lift, you have put in a higher spring rate, stiffer spring.
