Suspension to jump jeep?
JDZ1
2021 Rubicon 2dr
Serious question, coming from side by sides and this is my first jeep 2021 2dr rubicon. I want to be able to do SMALL jumps and moderate speed over woops. Is this doable in a jeep? What mods are required?
thanks!
SSWIM
Sam
Too Many
Nope. Not without a great deal of work. It will not even be close to a SXS. Sorry.
Sam
AcesandEights
Aces
So. Oregon
2021 Jeep Rubicon 2D
Probably a lot of work, but I'm sure you can calculate the necessary spring and shock combination given the weight and wheelbase of your Jeep, and based on what you want to do. Ford Raptors and Broncos can handle small jumps, so you could take the a/m spring manufacturer specs and a/m shocks and come up with a combination that would allow whatever you want. Rigs race Baja at 100+ mph, so you could engineer something.
That being said, I think the Jeep is the wrong dog for that hunt, but anything is possible.
roaniecowpony
Retired Engineer
Get another SxS, dirtbike, or 4wheeler. The Jeep frame doesn't have anywhere near the stiffness a SxS has and there are a lot more parts to break. Save yourself from a really bad dent in your wallet.
LiveToWork
Not here
2022 3500HD
Oil patch
This is exactly what i did. I asked about jumping my jeep on this forum a while back and got the same response. Bad idea. I bought a dirt bike/track membership and quickly lost interest in bashing my jeep.
blnewt
New Mexico
If your sand running getting a little hang time isn't too bad, but a hard surface is a whole new animal, and it's an angry one!
PatrickR
Patrick
North Carolina
2018 JLU
Look at the jeepspeed guys. Cycle 11+" of good suspension (easy part) and look at quality bumps (prothane is a cheap option). Be ready to upgrade what breaks, but it's definitely doable.
Oh and first gen raptor shocks bolt into the rear. There's a thread about that in the suspension subforum.
There's a guy famous for a video of hucking an xj over some massive jumps. He has a similar setup to what I described, with a little more suspension and springs in the 280 lb/in range.
JDZ1
2021 Rubicon 2dr
Yeah I completely understand it
Isn’t a side by side and not what I bought it for but if I see the right set it’s hard to resist. Just looking for some direction on some upgrades to keep it together over some small stuff.
engineXI
jank
so cal
rubicon
are coilovers better for that type of activities?
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Yes, because you can adjust spring rates easily and a lot more spring rate options, but you could probably valve a regular bigger sized smoothie shock stiff enough to do the job, but id stick to co and bypasses for that activity. For what its worth i keep up fairly well with my side by side, my shocks are valved pretty stiff with flexi rate plates but it does a damn good job in the dirt. Little rough on on street though
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
thanks!
Yeehaw!
roaniecowpony
Retired Engineer
Given enough credit limit on your Visa, it's within your grasp. 😜
Northridge4x4
