mgroeger
- Mike
- Feb 1, 2018
- Hurricane, UT
- 2021 JLUR 2.0T, 1991 YJ rock crawler
- Occupation
- I make microchips for a living.
- Vehicle Showcase
- 1
FORWARD:
The Jeep has been to the dealer to have this issue looked at. I was hearing a clicking noise and a knocking noise coming from the front end. Dealer went over every bolt associated with front end suspension and found that one of the shock bolts was 3/4 turns loose. That stopped one of the sounds but not the other.
When I go over certain speed bumps, the kind which are pretty aggressive, the front end will make a clicking noise. It goes like this... hit the speed bump, front suspension compresses, sometimes the bump stops are hit, the it springs upward (possibly full extension but not certain), makes a clicking sound and then returns to normal position.
The aggravating thing is it does not do it on every bump only the more pronounced ones. I took the Jeep and ran it straight up onto a curb. I could hear the bump stops being hit and then nothing else. So I hit the curb harder causing more compression and recoil and I could hear the clicking.
I've never had a Jeep or a solid front axle vehicle so I don't know if this is normal. It seems odd for a suspension to click when it is on full extension. I have another appointment at the dealer Wednesday. The Mrs. is cranky because I was going to put a lift on it this weekend but I know as soon as I do that they won't even bother looking at it as a warranty issue because I changed the suspension.
