Supertop Ultra - How do you secure the folded top?
WindyCityWilly
Chicago
2021 Willys
Last night I installed my Supertop Ultra and took the obligatory drive with the top in the fully down position. The install was easy enough and took about 3 hours without any help.
I did notice when I went over bumps that the folded top would bounce up and down. Am I missing a strap or something to hold it down?
WindyCityWilly
Chicago
2021 Willys
I ended up using a buckle strap to hold the top together. I had it out on the tollway last night and the top was no longer bouncing up and down.
Also, if you're thinking about getting one of these, I recommend replacing the phillips head screws that you use to attach the top to the frame with something that has a hex head. It's pretty difficult to get the phillips head screws fully seated without striping the head. You want a #6 screw that's 1/2" long, I used these plus a #6 washer and it made the job far easier
Jtclayton612
Memphis, Tn
2020 JLU Sport S
should be some Velcro right under where the locking levers are to wrap around the arms of the top.
