SunRider top - can’t get rear clamp to fit into place
Hightide drifter
Bob
DELCO
2022 Wrangler HighTide
So I decided to try and put my top on by my self can’t seem to get the rear clamp to fit into place any one one else’s have this problem
Thanks
Bob
UtahDirt
George
2023 Punk'n Rubicon 4xe
Is the top at the rear level with the freedom top? If you deform the factory seal when installing it makes the top sit high. Won’t insult you by asking if the front locks are unlocked 🙂I take mine off in winter and I learned to put silicone spay on the seal first in the spring. I get mine started then use a rubber mallet to LIGHTLY tap it on.
Steel8083
2021 rubicon
Slow down. Take a good look at clamp to see how it makes sense to fit. Mine was off a little and drove Me crazy
Hightide drifter
Hightide drifter
Bob
DELCO
That’s the issue when it’s in place it does not sit level with the rear top
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
It was hard the first time for me. Needed some force. But became easier as it got removed 3 or 4 times. You are doing that as the last step correct?
thance
New Jersey
2010 Commander, 2002 Liberty, Looking for JLURD
Do you have the sunrider on already? That clamp sandwiches the sunrider to the hardtop like a springless clothespin.
I tried to install it first and that doesn't work, needs to be last.
DiscoLemonade
Aaron
NWI
JLUR
I just installed my sunrider a few days ago. The rear clamp, that bolts the sunrider to the hard top, took a little force and wiggling to go on. It was much easier the second time I clamped it. Obviously, make sure the rest of the hardware is properly secured and flush with the mounting points. The back clamp is the last thing to go on.
Hightide drifter
Hightide drifter
Bob
DELCO
All is well top is on it did take a little work Thanks to all responded !
