karynm8621
one thing to consider if you're going to use a screw extractor set is to use a left handed drill bit. Sometimes when you're drill it will break the screw loose and the left handed bit allows for that screw direction
Valve grinding compound works well also. I use it on all Phillips screwdriversYou may be able to cut a slot across the fastener head using a dremel and thin cutoff wheel, then use a screwdriver to back it out. Be careful that you don’t cut all the way through the head. If you do, then you’ll need to drill into the bolt shank and use a small spiral screw extractor.
In the future, get some EZ Grip friction drops and use them on these stupid Torx fasteners to reduce the chance of stripping the heads by camming out like this.
That's pretty awesome, never seen one before.everyone should have one of these guys in their tool box/kit. https://www.amazon.com/TEKTON-2905-8-Inch-Manual-7-Piece/dp/B000NPPATS this would have kept you from having the problem in the first place. but to fix it, get yourself a good set of ez-outs and a good set of drill bits. quick fix for sure
they work really well. using a dead blow hammer nice a flat. first time i removed the bolts on my wrangler doors to remove them gave all of them a hit with this guy and they all came out without issues. Same with the painted hinge bolts. cannot recommend these enough for 20 bucks.That's pretty awesome, never seen one before.
THank you so much for your response. It is very much appreciated!I have used a chisel or punch and hammer to remove torx head fasteners before under similar circumstances. You run the risk of damage to surrounding surfaces if the tool slips off the fastener's face while tapping it out (counter-clockwise to remove),
You can remove the interior tailgate panel and see if the backside of this bolt is visible. That also might help in removing the bolt. I honestly don't know if you can see it though, I didn't pay attention when I had my tailgate panel off.
Very good idea. dont want any scratches .. ill do this for sure.did it move at all? if so, this is a total backwoods move, but, has worked for me more than once. vice grips on the outside edge.
whatever you do, masking take around its o You don't tear up your paint.
then, a trip to the dealer for a new bolt, with a pass by advance for some never seize.
nope not a bit.. the other one moved but not this stubborn onedid it move at all? if so, this is a total backwoods move, but, has worked for me more than once. vice grips on the outside edge.
