Stock Rubicon Wheels with MT/R's?
imthatguy
Toronto
JLUR Sting Gray, Cloth, 7" uConnect, PUNISHER STICKERS
Film Editor
Hey folks,
I want to run the stock Rubicon wheels with GoodYear Wrangler MT/R's (35/12.5/R17) and am planning on getting a subtle 1.5"Teraflex Spacer kit for a little extra room to stuff. My question, and I've seen various answers, is will I need wheel spacers to clear the extra rubber, or should I be okay without?
imthatguy
imthatguy
Toronto
Film Editor
Hey folks,
Nobody's running a 35" 12.5 R17?
Taxman
Alex
Raleigh, NC
1985 CJ-7, 2018 JLUR
CPA
This is a very common setup and one that I will be running when my stock tires need replacing. There are lots of threads about this topic. The general consensus is that you don't need wheel spacers if you plan to just drive around town, but if you want or expect to fully flex your suspension in an off-road environment, then you will benefit from wheel spacers to avoid rubbing the tires against your fenders. With a small budget boost, you may also want to consider extended bump stops and longer sway bar links. They are inexpensive and easy components to install/replace, but not always included with all basic budget boosts.
Good luck!
Next Venture Motorsports
