Stock Rubicon vs 2" Mopar lift
coolcj7
New York City
2020 Wrangler Rubicon 2-door
Can anyone clarify if the 2" Mopar lift actually adds any extra height to the stock Rubicon? Is it worth installing it? I can't find anywhere any before and after pictures for Rubicon. I know the lift actually changes the Sport models, but a stock Rubicon already comes with stiffer springs that add some height to the car. Is there a visible difference after adding the Mopar lift?
Thanks everyone!
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
Thanks everyone!
Yes, most report 2.5 to even 3" of lift with that lift on a Rubicon.
coolcj7
coolcj7
New York City
I got 2.5 inches with the Mopar lift on my Rubicon. Very happy with it.
So, you were able to raise it 2.5" above what you had before, correct? That is really cool!
drdriller
Houston
2019 jl
My 19 rubicon got 3.75” lift and now settled to 3.5” lift as measured from fenders befit and after. I’m happy with lift.
Ps. In Houston I had my mopar lift installed by mikes auto truck toys in Pasadena. I had to go back and tighten the hand tight bolts on the entire passenger side, including all the relocation brackets, control arms and shocks— yikes
DaddyEngineer
Tomball Texas
2019 JLU Rubicon
I only got 2-1/4” and it’s settled to 2” on my 19 JLUR.
BernJLUR
Bern
Bradenton FL
2019 Ocean Blue JLUR (on order), 2015 Anvil JKU, 1995 4.0L YJ
Definitely taller after 2” lift. Top pic is OEM lift with OEM tires. Bottom is 2” Mopar lift with BF KO2s 315 (34.5ish inch) tires. It makes the larger tires look small. No measurements though.
MORubi
Bill
Kansas City MO
2018 Red JLUR, 2014 Jeep Grand Cherokee
Construction
Is the Mopar lift enough on a Rubicon to allow for 37s?
Yes, but you have to have enough backspacing on your wheels. Also, the back plastic fender well liner has a hump from the factory that might have to be removed or pushed in using a heat gun.
BernJLUR
Bern
Bradenton FL
BigBruse
Robbie
Va
2019 Jeep rubicon
Did you have to add anything to the mopar lift for a rubicon?
Extreme Terrain
