californiajeeping
- Feb 1, 2019
- California
- JLUR
When I measure the front passenger side wheel well from the ground on a flat concrete pad on my 100% stock JLUR, it is 1/2 inch lower than the front drivers side. The tires have the exact same PSI, no one and no cargo on board. The two rear wells are the exact same height to each other so I don’t think this is the “Wrangler lean”.
Can someone with a stock JLUR measure and check to see if there is a similar difference? The gas was closer to empty than full and because the rear wells are the same height I wouldn’t think that gas weight would explain it.
I’m checking this because two different people said they felt it was leaning and I’m troubleshooting a driving characteristic that could be caused by aerodynamics. I might have a bad shock or something.
