Stock height and wheels rubicon on 35’s vs Xtreme Recon package
Rowbaretow
Robert
Oregon
Jeep Wrangler Rubicon 4xe
I am planning on installing the same 315/70R17 KO2s on my 4xe Rubicon JLU that come on the xtreme recon package. I don’t plan on a lift or wheel change.
I would like to see a side by side of what I want to do to mine and then an Xtreme Recon package jeep. Is the 1.5in lift, wheels, gearing, and what not worth it truly? Looks wise that is. Performance wise I am not a rock crawler and do mild off-roading like most.
I really just want to keep up looks wise with all the soon to be Sasquatch Broncos that are going to be hitting the road. But I don’t want to necessarily spend an extra $2k on the mopar 2in if it doesn’t make stance and appearance better. I don’t need it functionally. We all want our rigs to look good.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
So chuck a small spacer lift in it and be done. That ought to keep those Sasquatches from intimidating you at stop lights and whatnot. ;)
JLWarrior
Ryan
Philadelphia
2020 JL RUBICON
Following. I’m looking to do the same. Putting some 315 KO2s on my JLUR. Looking to replicate the Xtreme Recon height and spacing. Haven’t found a clear answer yet.
JJsJL
NE
2022 JLUR ER, 2008 JKU Sahara, 2023 Yukon XL,
Hey guys. You can put 35's on your stock Rubicon suspension. Will it look better with a XR set of springs on it. Yes it will. But your getting tall enough now you should look at longer lower control arms so if you go that route look into buying some lower control arms. The steering will be much better with the Caster adjusted. Speaking from experience, small lift and larger tires satisfies you for about 6 months then you will get used to it and wish you would have just gone a little higher. I will include a series of pictures of my Jeep stock/35's stock suspension/35's with Mopar 2". Then I will include a pic I stole from SmileyRecon21. Look him up on the Forum. He replaced his XR lift with the Mopar 2". The pic I took from him is with the Mopar on his XR edition on the 315's that came with it.
Rowbaretow
Robert
Oregon
This right here is all I’ve been wanting. Thank you. Helps so much with where I want to take my Jeep.
landshark99
Bob
2019 JLU Rubicon
I had 315s on my JLUR they are slighter wider and shorter than 35's
first image 315s with Method Wheels and 2.5 lift
second image is 37s all the rest is the same, both the the 37s and 35s are 12.5 in with the 315 slightly wider
GATORB8
CLT NC
21 JLURe
Just skip the 35s and go straight to 37s :)
Stock, 35s stock, 35s TF 1.5” spacer, 37s spacer, 37s MC 3.5”
Jeep Wrangler JL Stock height and wheels rubicon on 35’s vs Xtreme Recon package 5DFB41E0-4965-4E57-9ABA-DEC9A3EB4D21
Jeep Wrangler JL Stock height and wheels rubicon on 35’s vs Xtreme Recon package 3E3FBC6A-885B-426A-BF5A-05A90486242C
Jeep Wrangler JL Stock height and wheels rubicon on 35’s vs Xtreme Recon package FD503ACE-6DEA-4218-8871-EC4D4B375EF8
Jeep Wrangler JL Stock height and wheels rubicon on 35’s vs Xtreme Recon package BB6F6295-AB08-4777-B984-59CA41F0C796
Jeep Wrangler JL Stock height and wheels rubicon on 35’s vs Xtreme Recon package 4C627F96-5127-4372-91C6-D4DF8CC0BF46
JLWarrior
Ryan
Philadelphia
2020 JL RUBICON
I personally like the second photo; were the 35’s the 315 KO2s? What are the rim specs? It’s amazing how much the 1.5” TF spacers added to the wheel well height. This is super helpful. I might just go with photo #2 + 3/4” spacer lift so give a little more clearance.
GATORB8
CLT NC
21 JLURe
Those are the 35x12.50 E loads, only way to get the white letters.
Note, the TF 1.5 is a 2” front spacer and 1.5” rear.
And I did not go off-road before lifting and adding 2” bump stops. No rub on road.
wheels are 17x8.5 +18mm
JLWarrior
Ryan
Philadelphia
2020 JL RUBICON
Thanks! I might go for a 1” front spacer and 3/4” rear spacer after seeing these photos! Thanks for sharing.
Going for this look …
