Sold: Washington STL 4 switch box
MyDaughters20JL
WA
20 JL Sport S
Made by STL, this switch box allows for the addition of up to 4 accessories with A-C being on/off and D being a momentary switch.
Wiring is pretty straightforward:
red "+" wire to positive battery terminal
Black wire "-" (common ground) to negative battery terminal or body bolt
when wiring accessories, simply attach the positive wire from the accessory to the preferred switch wire (labeled A-D) and the negative to the black wire "-".
I purchased this for my daughter for Christmas & she just told me she likes the looks of the voswich jl300 because it more closely matches her interior dash area
$35.00
Jeep Wrangler JL STL 4 switch box IMG_5724
Jeep Wrangler JL STL 4 switch box IMG_5723
Jeep Wrangler JL STL 4 switch box IMG_5725
Chris.steger
Noblesville, IN
2020 Wrangler JL
Curious, do you know if the switch module would fit inside the full width pocket under the HVAC controls?
Then just run the wiring out the back of the pocket..
MyDaughters20JL
MyDaughters20JL
WA
20 JL Sport S
I’m not really sure, my Rubicon came with the rocker switches and auxiliary switches so I don’t know for sure of the size of the pocket under the controls. I have attached a picture from the manufacturers website of the dimensions of the box: I will let you make the final decision on whether or not it will fit
Jeep Wrangler JL STL 4 switch box C111728E-8A45-4A9C-AF91-29EEDB240EA3
Chris.steger
Noblesville, IN
2020 Wrangler JL
Awesome!!
This is perfect..
I will measure after work today- it it fits, I will send you a message..
I definitely want it if it will fit...
Chris.steger
Noblesville, IN
2020 Wrangler JL
Well,,
i just measured the height of the box vs the height of the pocket..
It won't fit..
Dang it.. Would have been a perfect idea...
Thank you though.
