I'm going to be getting these soon If anyone is interested, here's the link https://www.quadratec.com/p/quadratec/pre-runner-led-light-bar-kit-jeep-wrangler-jkAdded some lights
BTW, it looks like a pretty easy install. Was it? I've never messed with anything electric, but the video seemed really straight forward.Added some lights
Everything was straight forward except getting to the side marker lights wire. In the instructions they say locate it from under the wheel well, but the only way you’re getting to it under the wheel well is if you pull out the plastic trim (which I wasn’t interested in doing). So I had to access it through the engine bay, which was a little awkward. Other than that, pretty easy.BTW, it looks like a pretty easy install. Was it? I've never messed with anything electric, but the video seemed really straight forward.
It looks really goodEverything was straight forward except getting to the side marker lights wire. In the instructions they say locate it from under the wheel well, but the only way you’re getting to it under the wheel well is if you pull out the plastic trim (which I wasn’t interested in doing). So I had to access it through the engine bay, which was a little awkward. Other than that, pretty easy.
As a little added advice, when you go to cut the honey comb grill, cut off as little as possible. I took a little too much off the center grille slot so the light was loose in the hole. I had to use some black electric tape to tighten everything up.
Thanks man. I’m thinking KC a-pillar lights nextIt looks really good
I like the color because of the back ground but I like the Black and white one because you were able to process more details out of the Jeep and reflection.B&W and color....which one do you like more...?
Color, looks like your Jeep landed in the most epic part of the Star Wars Universe! (The part with no political agenda, just bad *ss locations!)B&W and color....which one do you like more...?
I can't. They're both gorgeous.B&W and color....which one do you like more...?
She grew up a little bit I totally forgot to post picturesWent from a 16 hard rock to a 2020 jlur
