Step attachments for OEM Rock Rails
Steemax
Los Angeles
2022 Rubicon 4xE, 2025 Outback Wilderness
I've been looking around without much luck but does anyone know if add on steps exist for the OEM rock rails? I like the OEM rails and only take an off road trip twice a year so something that can be removed with a couple bolts before heading out on a trip sounds appealing to me.
Currently I've only found one made by Trigger that Quadratec sells but it's listed solely for the JK.
Thank you,
GreySportySpice
Drew
South Jersey
18' JL Sport 6MT, 21' Bronco Sport OB
Mechanical Engineer
Ace engineering has rails that mount in addition to the OEM rock rails. I don't think they are steps exactly but it might be worth looking at.
Steemax
Steemax
Los Angeles
Thanks, I just checked these out but it's pricey at $1k+, probably better to replace the entire sliders at that point.
This is along the lines of what I was looking for, thank you,
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
If you like the ACE option, other than price, extreme terrain's house brand barricade has a set that work with the rails: https://www.extremeterrain.com/barricade-rock-sliders-2018-jl-4-door.html
Personally, if you get into off roading, I'd at least consider a solid frame mount set of sliders.
GreySportySpice
Drew
South Jersey
Mechanical Engineer
Good spot! Ive been eyeing this stuff for a while myself. Didn't realize they had this.
The way I see it WHEN the cheaper steps rust a little then it doesn't matter, it's below the body.
GATORB8
CLT NC
