Steering wheel wobble?
TimP
Tim
Castle rock, CO
2017 wrangler sport
They replaced my track bar and it made no change.
I am at the dealer dropping it off again, if it’s not fixed this time I think I’ll be utilizing my companies lawyer benefits to deal with it.
40k vehicle and I can’t safely drive it after 5 months. I’m beyond annoyed with this. It’s continoually getting worse too, today on the way to this appointment it was so bad I had to slam the brakes and pull of the road.
jeremyjeep
Jeremy
Jeep, USA
JLUR
40k vehicle and I can’t safely drive it after 5 months. I’m beyond annoyed with this. It’s continually getting worse too, today on the way to this appointment it was so bad I had to slam the brakes and pull of the road.
Make sure they check the torque on the ball joints as well. And no, not visually inspect it, take off the cotter pins, check torque, then re-insert the cotter pins. Torque cannot be checked with the cotter pins still installed. All 4 in the front. If you turn the steering wheel far left or right, you can see them without crawling under the vehicle to verify if they removed the cotter pins or not. New cotter pins will be bent perfectly from the factory. Replaced cotter pins will look like a human put them and bent them with a pair of pliers.
It looks like this guy's JL's ball joint nuts were so loose, that they came completely out.
https://www.jlwranglerforums.com/fo...-is-this-an-isolated-case-or-a-problem.17516/
And many in the steering thread are finding their ball joint nuts were so loose, they could remove them with their fingers.
Martindfletcher
Martin
San Diego
Ducati 1299s, 2018 JLUR
I am not sure the loose ball joint could cause this issue. Could be wrong, but the torque from the bolts seems to pulling against the press fit.
TimP
Tim
Castle rock, CO
2017 wrangler sport
They replaced the ball joints on the last visit, I’d like to think the torque was re-done st that time lol
TheJoyceIsYours
Brendan
St. Joseph, MI
www.lbdesignworks.com
2018 JLU Sahara
Designer
Ok update from the dealer... My wife talked to them and relayed the info very well, but it sounds like they told her after creating a case with FCA, and waiting on a response, today they issued a TSB on the steering stabilizer. Part was on back order and could be till 2019 when the part would be available. We should know more next week.
jeremyjeep
Jeremy
Jeep, USA
JLUR
Do you have any info on this stabilizer TSB? Like a TSB number? Or anything? I don't see it on the Recall / TSB list here yet - https://www.jlwranglerforums.com/forum/threads/steering-wheel-wobble.16577/page-7#post-433876
TheJoyceIsYours
Brendan
St. Joseph, MI
2018 JLU Sahara
Designer
Just repeating what I heard, but unfortunately I do not. I called the earlier today and they said they were waiting to hear back from Chrysler engineering (normally only took a few hours apparently) since Wednesday AM basically.
Will add updates as I get them, but I know I don't want to drive this base Cherokee for too much longer... i guess It was nice they gave me a loaner till I get my Jeep back, so I'll be thankful for the positives!
XJrider
North East
Rubicon JL , 2 JK’s , XJ
No one seems to know the answer here so...
You need more caster i recommend 5.1-5.4 degrees even stock not lifted . And put your tire pressure down to 33-34.
Command Line RC
Cleveland OH
2018 Jeep JL Wrangler Unlimited
Yesterday, I decided to remove the wheels and spec out the bearings...again...and worked my way all the way up to the steering column. Everything seemed legit. I removed the steering stabilizer and noticed that I could actually move this thing back and forth with my hand with relative ease. Installed the Falcon steering stabilizer and noticed a dramatic difference. I could actually drive on the interstate with one hand now...no more white knuckling the steering wheel! No more death wobble.
jeremyjeep
Jeremy
Jeep, USA
JLUR
What was the symptom before you installed the Falcon steering stabilizer? Could you turn the steering wheel 2+ inches before the tires turned? Or something else?
Command Line RC
Cleveland OH
Yes the symptom was before the after market stabilizer. Yes again, I had about an inch and a half of play in the steering wheel and now I have zero
jeremyjeep
Jeremy
Jeep, USA
JLUR
Hopefully this steering stabilizer TSB or recall that someone said their dealer brought up will come out soon. Seems everyone is adjusting the steering box to remove the excessive play in the steering wheel.
Jim Marsh Chrysler Jeep
