Steering Stabilizers
ksmit88
LA
JLU Rubicon
I’m getting ready to pull the trigger on a 2.5” lift for my JLUR. At what point should I look at steering stabilizers? I plan on keeping the 33” stock tires for a while but eventually want to go 35”. When is it a good idea to upgrade a stabilizer? Thanks
Spank
Probably never.
Other than having to replace one that was damaged or literally torn off on the trail, there really is no need to "upgrade" a steering stabilizer. Unless you start replacing some serious hardware, like axles and powertrains, and decide something crazy like 40's belong on your Jeep, the stock one is more than adequate.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
What @Spank said. :like:
The only aftermarket stabilizers I really like are the through shaft adjustable ones. I like the ability to have firm steering feel on road, then turn it all the way soft while rock crawling.
AZCrawl
AZ
2018 Granite Jeep JLUR
Teraflex should have one out soon. They had them at EJS I heard.
kkuntz01
Mount Juliet, TN
2018 JLU Rubicon, 2014 Ram 2500 Crew Cab
With what you're planning, you should not need to upgrade. At some point you'll need to replace the stabilizer like if you damage it while off roading or it wears out when you eventually upgrade to a bigger tire.
Merlin28
Peter
New Jersey
3 JK Sahara builds , JL Rubicon, 95 XJ build
What lift are you planning on using?
Merlin28
Peter
New Jersey
So there’s no caster correction which means you’ll feel like it’s wandering at times. SS not needed for 33’s . This is yrfirst jeep?
My#8andlast
Ken
Knoxville, TN
Mine doesn't wander. I did get an alignment but from what I hear it's not needed. It's my 8th Jeep (CJ, YJ, 2x TJ and 3x JK).
Merlin28
Peter
New Jersey
How’s the angle of the lower control arms . Parallel to ground? Then this shouldn’t be a surprise to you. If yr running good caster the stock stabilizer should work... yea you could drop 400 on an ats set up but I’ve always felt they mask bigger problems...
My#8andlast
Ken
Knoxville, TN
I've always thought steering stabilizers were more about tire width than anything else. I'm running a 12.5" width and have no issues. Most 33's are the same.
bodam
Bob
Cypress, TX
2018 Jeep Wrangler
I installed the RC steering stabilizer today and it made a huge diffeeence in handling.
Kysport
Louisville
2018 Wrangler JLU Sahara
So is the Rough Country better than the stock stabilizer? I will gladly spend the money if it handles better at highway speeds.
