Jteakus
Oil City Louisiana
2020 Ecodiesel Unlimited Rubicon
Last time I talked to PSC they had an Ecodiesel JL in their possession and were working on a traditional belt driven pump and heavy-duty steering box. I guess that will be my route. Congrats to everyone that got their’s tracking true.
JayJay
Johnny
North Georgia
'20 JLR
Wonder if something encroaches into the area the new steel box occupies on a Diesel? Would be a real cluster to need a unique box for that model.
Someone said that it is as simple as the diesel box has a different steering ratio than the gas version. I guess that Benny at Mopar parts could advise if the aluminum boxes were different part numbers between gas/diesel.
Later,
Johnny
Spdu4ia
Travis
2020 2dr Rubi
Picked mine up today definitely better, sorry all you having issues getting it done. Fluid Level is on low but ill keep an eye on it.
It still drives like a solid axle jeep but much smoother and I can one hand it doing 80mph.
I did verify I had the right part number on the box when I dropped it off for the 2dr thanks to you guys/girls
RV Wrench
Paul
West Richland, WA
84 Cherokee, 93 Wrangler, 19 Wrangler
Same here. Got mine back today with same results. Noticeably improved sensitivity in the steering.
zrickety
Technician
My new steering box came today, not bad considering I ordered just a couple weeks ago. Shipping took it's toll but luckily everything looks ok inside. The bolts coming from the other dealer have also shipped.
Jeep Wrangler JL Steering issues cured by installing new Steering gear box! (per TSB 08-074-20) IMG_20201021_200744500
Jeep Wrangler JL Steering issues cured by installing new Steering gear box! (per TSB 08-074-20) IMG_20201021_201215925
Ish22
Ish
Chicagoland
2019 JLUR Bright White
FYI everyone, make sure to look at your RO when you pick up your JL and be sure they install the correct steering gear box for you. While I was waiting for a porter to pull mine around I noticed the steering gear box was for a 2 door (I have a JLUR). I pointed it out to the advisor who looked to be sure that it wasn’t just wrong part # on the RO. Sure enough the wrong one (2 door gear box) was installed.
Jennalee
Jennalee
Los Angeles, CA
2020 White 2 door Willys V6 Automatic
Same here. They installed a 4 door on my 2 door. My Jeep is back in the shop waiting. Was told my new gear box is coming in on October 28.
JeepCares
Auburn Hills, MI
JL
Hello @Ish22 and @Jennalee
We regret to hear about the outcome of your initial steering repairs. Our team would like to document this for further investigation, as well as offer our assistance if needed. Please send us a private message with your VIN, mileage, and servicing dealer. Thank you!
Kathryn
JeepCares
Jteakus
Oil City Louisiana
@JeepCares Why no fix for the sloppy steering box on The Ecodiesel JL?
stevieb92
Pittsburgh, PA
2020 JLU Rubicon 2.0t
Mechanical Engineer
Mine is going in next week for this repair. Is it spelled out on the repair order that the box is a 4 door or 2 door? Or do I need to look up the part numbers? Just curious.
Cookie Monster
Northern Virginia
2019 Ocean Blue JLURT
Farrish Jeep in Fairfax, VA said they needed to inspect before they could order the parts. Yesterday, they inspected and agreed to order the tsb parts. They did not give me any trouble for my 2" lift. After cautioning me when I made the appt that the parts would take 4-6 weeks, the adviser during pickup mentioned the parts should be released for shipment in 3 days. We will see which it is.
So 5 and a half weeks later, I get the call, parts are in, you can come in tomorrow and get the tsb performed. I dropped off the Jeep yesterday, walked 1.5 miles to work, and in the afternoon I got the dreaded, "please call us back VM" instead of the "your Jeep is ready VM". I called, "They didn't have all of the parts, so we are overnighting what we need". So I walked back to the dealer, picked up a renegade loaner and drove home. I had to grab something from the jeep, so I popped the hood, and the original steering box is still there. I now plan on verifying the part number on the receipt and visually inspecting the jeep before signing the paperwork.
In other news the renegade has a gutless engine which seems to only make more noise with extra throttle, not more power. The windshield induces tunnel vision due to the large and forward placed A pillars. And the seat backs seem like they were designed for the 5'9" and under crowd. Fuel economy is only 1-2 mpg better than my 2.0. So I am very happy with my wrangler purchase.
blnewt
New Mexico
Just ask @cosine he knows!
It will list only the part#s not the vehicle application.
68507569AAGear, Steering - Four Door, Left Hand Drive (JL)
68507571AAGear, Steering - Two Door, Left Hand Drive (JL)
JeepCares
Auburn Hills, MI
JL
The Ecodiesel steering part is expected to be available in the first quarter of 2021.
Darlene
Jeep Cares
FredC
Fred
Hoschton GA
2020 Jeep Sport Unlimited
So just an FYI to those of you who had this done.
Mine was done about 3 weeks ago. When I got it back the PS fluid was right at the mid way between min and max level in the reservoir.
Over those 3 weeks it's dropped to below the min, but still above the bottom of the reservoir - so not empty or sucking in air.
I've looked for leaks and none, and topped it back up and will watch the level.
I can only assume it was not fully "burped" and some air came out that took in the additional reservoir fluid.
So keep an eye on the fluid level.
As an FYI AAP sells compatible Pentosin CHF11S fluid which is MS-11655 certified - not cheapest place to get it but open to 9pm on Saturdays.
