Harsh
Ok thank u!
If you don’t have the tools to do I would have dealer check again
Ok thank u!
I’m no expert.Yes exactly what I’m experiencing, thinking if the synergy steering brace would help with this or not?
They knocked it down to 1/2 hour. I think they removed the sway bar to allow a crows foot or open end wrench on the pitman arm not instead of removing the track bar, but I’m not really sure. The tech did a piss poor job of cleaning the steering fluid he spilled.Wow! Tell those techs to take their panties off the next time they come to work. I remove 1 bolt of my endlinks every time i had to "toggle" the synergy brace on/off for my wife's TSB. I've done it 3 times now and it took me all of 10 mins (the endlink bolts). At MOST, they should charge you 0.5hrs. Now, all that being said: it doesn't look like your endlinks interfere at all, so those must be BIG GRANNY PANTIES!! lol Good luck on your experience!
It looks like you could use some Rock Krawler lower spring pads to correct that outward bow.I just received this text from the dealership. Kind of irritated and the picture certainly doesn’t help much. Thoughts?
68507571aa | Power Steering Gear | $327.00 | 1 | $327.00 |
Not sure what your bottom 3 line items are but not sure that is correct. the TSB calls out a different part number for the 4 bolt package - 06513396AA Bolts, Frame - Steering Gear (4 Bolts Per Package)For whatever reason, the 2 door steering box is cheaper than the 4 door.
At least on moparfactoryparts.com
I was able to order everything for $387 shipped.
Note, they list the 4 bolts as 2 part numbers they are different lengths.
Edit- it looks like they listed the older bolts with the new ones, I'm trying to figure this out.
68507571aa Power Steering Gear $327.00 1 $327.00 6506950AA Hex Flange Head Screw $2.80 1 $2.80 6036780AA Hex Nut - Coned Washer Nut And Washer $3.63 1 $3.63 6512518AA Bolt $5.24 2 $10.48 6512519AA Bolt $6.55 2 $13.10
Subtotal: $357.01 Estimated Shipping to 31709 via Standard Shipping: $30.28 Total: $387.29
Thanks, I updated the post. Their site listed the old and new pumps together, but only the old bolts. The nut is probably being resued by the dealers, but I got a new one. I found the correct bolts for $29 shipped elsewhere.Not sure what your bottom 3 line items are but not sure that is correct.
6506950AA | Hex Flange Head Screw | $2.80 | 1 | $2.80 |
6036780AA | Hex Nut - Coned Washer Nut And Washer | $3.63 | 1 | $3.63 |
06513396AA | 4 | $ 4.73 | BOLT. NONE. |
1 products , 4 items | $ 18.92 |
Do you think the longer LCA’s help wandering on a all stock rubicon? Have no other steering issues...I always thought the pretty constant correction of wandering was inherent of drag link style suspension steering?Steering box replacement does not affect alignment. To change caster you need longer LCA - decreases wondering.
It did mine. Can't quantify the improvement but even my wife's comment was "Wow!".Do you think the longer LCA’s help wandering on a all stock rubicon?
I put Mopar longer LCA on my 2020 JLUR recently, and it tracks much better. My 2020 came with AE steering box from factory, and it was in general not big of wandering issues, but gets a bit loose on hot days. Longer LCA made improvements. You might have different results if your steering box is older version, and if the box itself is not good.Do you think the longer LCA’s help wandering on a all stock rubicon? Have no other steering issues...I always thought the pretty constant correction of wandering was inherent of drag link style suspension steering?
Thanks. Sounds like it's worth a try...Do you need to realign front end after installing the longer LCA's?It did mine. Can't quantify the improvement but even my wife's comment was "Wow!".
Later,
Johnny
No.Thanks. Sounds like it's worth a try...Do you need to realign front end after installing the longer LCA's?
